Re: First Drive in 32 years!!! [Re: Webster] #1442343
05/28/13 10:22 PM
05/28/13 10:22 PM
Mt. Eden Ky.
Hemi Allstate Offline OP
Mt. Eden Ky.
Thanks Terry, for your kind words.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: First Drive in 32 years!!! [Re: fstfish66] #1442344
05/28/13 10:28 PM
05/28/13 10:28 PM
Mt. Eden Ky.
Mt. Eden Ky.
congrats sounds meen,,,, look for my cuda at bowling green, im sure the new owner in KY will have it there
Hey Don,
If I make it to BG I will keep a look out for your Cuda. Do you miss it yet?
Mark
MARK, congrats on the killer J do i miss it you ask ?? a little over 28 years ago i pulled that cuda out of a cotton field in mississippi, as a rust free shell, it went thru a few changes over the years, till i finally had the cash to turn it in to the pro street machine i always wanted as a kid, if my work schedule was more off tiem friendly, ide of kept it im sure,,and made a few more changes,,probably turned it in to a more of a pro touring type car,, as i sell off the tons of extra parts ive collected over the years, i start to realize that its gone,,,,thanks for asking enjoy your J
28 years is a long time with a car. I had another car for 22 or 23 years and did a complete top to bottom rebuild on it...... I miss it!!!
1996 Ram 1500 Sport
1968 road runner
Re: First Drive in 32 years!!! [Re: Hemi Allstate] #1442345
06/19/13 03:06 AM
06/19/13 03:06 AM
PA
bbrroowwnn Offline
bbrroowwnn  Offline
PA
Very nice ride Mark....That motor sounds awesome...Not many Henry J's around
Re: First Drive in 32 years!!! [Re: Hemi Allstate] #1442346
06/20/13 08:35 AM
06/20/13 08:35 AM
Kentucky
Flipper1938 Offline
Flipper1938  Offline
Kentucky
So.....what did it run?
Re: First Drive in 32 years!!! [Re: bbrroowwnn] #1442347
06/28/13 11:49 PM
06/28/13 11:49 PM
Mt. Eden Ky.
Mt. Eden Ky.
Thanks Paul,
It seems to be ready, from what I can tell on the few short drives I have made.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: First Drive in 32 years!!! [Re: Flipper1938] #1442348
06/28/13 11:57 PM
06/28/13 11:57 PM
Mt. Eden Ky.
Mt. Eden Ky.
Richard,
The Ohio Valley Reunion, was rained out. As it turned out, that was probably a good thing for the Hemi Allstate. There were a few things that just were not "right" and could have caused some damage to the car. The event will not be run this year. I am hoping to get out for a TNT pretty soon. Need to be sure my trailer and tow vehicle are ready as well. I think we are very close.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: First Drive in 32 years!!! [Re: Hemi Allstate] #1442349
06/29/13 08:32 AM
06/29/13 08:32 AM
moparx Offline
moparx  Offline
any numbers you mite be feeling confident it will do ?
Re: First Drive in 32 years!!! [Re: moparx] #1442350
06/29/13 01:43 PM
06/29/13 01:43 PM
Mt. Eden Ky.
Mt. Eden Ky.
Not really Eric.
The last pass was in 1981 1/8th was a 6.43 @ 108 and 1/4 was a 10.43 @ 129 (too much gear).
It really is a different car now. I don't know what it weighs, or how much HP the engine makes.
If the car weighs in @ 2600 lbs. with me in it, and the engine will make 750 hp, then it should be much quicker than before!
It used to weigh 2490 lbs. less driver, with a cast iron BBC. It had leaf springs on front and rear, drum brakes, narrowed OLDS rear, plexi windows, huge ladder bars, and a three point roll bar. I think these are the major differences. The new engine is supposed to be just over 500 lbs., QA1 coil overs, Wilwood disc brakes, glass windows, ladder bars, and complete cage.
Indy rates their 572 @ 770 HP. Mine is very similar in specs, but I think I have a better set of heads. (Stage V CNC @ MCH )
So, would you care to guess? LOL I weigh 182 lbs.
1996 Ram 1500 Sport
1968 road runner
Re: First Drive in 32 years!!! [Re: Hemi Allstate] #1442351
06/30/13 09:14 AM
06/30/13 09:14 AM
moparx Offline
moparx  Offline
Not really Eric.
well, i think i will lock in my numbers. [remember the show 'pass time'?]......
i would think you should have no trouble going an easy 9.88 or so with a cautious tune and taking it easy on the first few passes. just a W.A.G. from a guy that is dummer than a bag o hammers....
but you will be faster than me 'cause i weigh 20lbs more than you ! good luck and keep us up to date !
Re: First Drive in 32 years!!! [Re: moparx] #1442352
06/30/13 02:02 PM
06/30/13 02:02 PM
Mt. Eden Ky.
Mt. Eden Ky.
Eric,
I had the car NHRA certified for 8.50 and slower. While he was looking at the car I had him do a tech inspection, as if we were at the track. I fixed a couple small items he said needed to be done. So that is out of the way. I need a check mark smiley.
A lot of rain around here lately.
I need another test drive on the street to check out some of the adjustments I have made.The wheelie bars would have hit the rear roll pan the way things were, if the car went into a wheelie. I raised the rear of the car and adjusted the shocks, on all four corners.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: First Drive in 32 years!!! [Re: Hemi Allstate] #1442353
06/30/13 10:06 PM
06/30/13 10:06 PM
moparx Offline
moparx  Offline
sounds real good mark. did you plug your weight & hp into any calculators to get some idea what might be capable ? how accurate are calculators anyway ?
Re: First Drive in 32 years!!! [Re: moparx] #1442354
07/01/13 11:12 AM
07/01/13 11:12 AM
Mt. Eden Ky.
Mt. Eden Ky.
Yes I have Eric,
I tried to estimate the HP conservatively @ 750. I think it may have a little more in it with a good tune, and maybe a bigger carb. The weight should be around 2,600 lbs. , but could actually be less.
So, 750 HP @ 2600 lbs. on the Morosso slide is : 8.70 @ 156 mph. Hmmmmm....... Lets try 700 HP @ 2700 lbs. : Still 9.0 @ 150 mph.
I may want to stay on the 1/8th mile!
Mark
Here is a link to Wallace Calculators : http://wallaceracing.com/hp-correction-quarter.php
1996 Ram 1500 Sport
1968 road runner
Re: First Drive in 32 years!!! [Re: Hemi Allstate] #1442355
07/01/13 09:16 PM
07/01/13 09:16 PM
moparx Offline
moparx  Offline
well, i guess my 9.88 taking it easy should be in the bag ! the other .8 will come around quickly as you get a few bugs worked out. i just wish i could be there.......
Re: First Drive in 32 years!!! [Re: moparx] #1442356
07/05/13 07:29 PM
07/05/13 07:29 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
MARK.MARK.MARK..You rock guy..I luv that Allstate..want to junk my junk now..Wish I was closer..I want to be there for the first pass..Make sure you get a good video for us losers that can't get there to watch..I can't even send a pic of my 56 since my P/C crashed.. all the best Mark, Larry
Re: First Drive in 32 years!!! [Re: dynamite] #1442357
07/07/13 04:47 PM
07/07/13 04:47 PM
Mt. Eden Ky.
Mt. Eden Ky.
Hey Larry,
I am sure that your car is far more street-able/ useful than the Allstate. The aluminum engine makes a lot of condensation. Another issue to deal with.
Anyway, it sure feels good to have you and these other members cheering me on to my first pass. I hope I do not disappoint you guys.
I will certainly try my best. I hope to have someone making a video.
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
