idle mixture screw setting #1442311
05/26/13 03:16 PM
05/26/13 03:16 PM
Maryland
cudaboone Offline OP
Maryland
On holley 4500 four corner idle. if running too rich, do you turn the screw in or out to make it leaner? I dont have a vacuum port. Guess i should have installed one on my manifold.
Re: idle mixture screw setting [Re: cudaboone] #1442312
05/26/13 03:18 PM
05/26/13 03:18 PM
Kirkland, Washington
Pacnorthcuda Offline
In, clockwise, is leaner
Re: idle mixture screw setting [Re: Pacnorthcuda] #1442313
05/26/13 03:23 PM
05/26/13 03:23 PM
Maryland
Maryland
Thanks, that was quick.
