I saved a 74 RR from being parted out a couple of years ago.
Great paint, options codes except the damn 318.
Still has original 904 tranny and rear end, but a random 318 from a late 70s truck just to keep it drivable.
It was a stalled project that had had the side marker lights, antenna, and fender indicators shaved and in primer. I would have let it get parted out but I felt bad for it being a factory sun roof car. Came with original console, but Monaco front buckets (right frame anyways) and interior panels from a 73 satellite I cut to use 74 rear seat belt roller inserts with. No one makes the head liner for it.
I did a 200$ driveway paint job and stripe kit, spoiler, and dashcap, bigger rims and new shoes. Got all lights and wipers working, still working on horn. Seriously needs front end rebuilt/susp.
For the drivetrain I can:
LA 360 - probably cheapest
stroked LA 360
crate LA 360 drilled to also take magnum heads
360 Magnum- mounts, accessories, up goes the cost
salvage 5.7 Hemi/tranny complete- more cost, not sure if can sort out computer, electrics, gauges, etc.
When all is said and done,
for those of you just wanting a fun, reliable driver you saved and not a valuable, rare, etc. car/restoration-
what has been the easiest, best bang for the buck when you were in my shoes.
Thank you for your information.
