PCV valve #1441868
05/25/13 08:28 PM
05/25/13 08:28 PM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
hi guys , just a quick question , why did 68 & 69 , 383s & 440s , have the pcv valve on the passenger side valve cover from the factory , yet in 1970 it was switched to the driver side valve cover ? think i may have read sometime ago having it on drivers side is better ?
any info / feed back on this would be appreciated
Re: PCV valve [Re: A47] #1441869
05/25/13 08:36 PM
05/25/13 08:36 PM
Functionally it'd be the same so I'd guess there was a part addition/change that forced it to be moved to the other side to avoid interference but I'm just thinking out loud on a Sat night
Re: PCV valve [Re: RapidRobert] #1441870
05/25/13 09:21 PM
05/25/13 09:21 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If I was to guess and that's all it is, I would guess because of oil windage.
Don't be the exception.
Re: PCV valve [Re: Supercuda] #1441871
05/26/13 12:12 AM
05/26/13 12:12 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
The right-handed guy quit and a left-handed guy took his place.
Nah, just kiddin' - likely there was some cost that they wanted to reduce when they changed the breather cap & hoses; fuel line's on the right side, and fuel vapor recovery probably played into swapping sides.
Re: PCV valve [Re: topside] #1441872
05/26/13 02:24 AM
05/26/13 02:24 AM
Nobody at the big comapnys make changes unless it saves them money or they had to comply with some new goverment regulations, and we all know who pays for those changes to comply , correct
Re: PCV valve [Re: Cab_Burge] #1441873
05/27/13 09:17 AM
05/27/13 09:17 AM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
thanks guys , for the replies & input
appreciated
