intake centerline question #144176
11/01/08 09:10 AM
11/01/08 09:10 AM
OH
Lynch Rd Runner Offline OP
OH
My friend is mocking up a new motor. He now has it adjusted so none of the valves will hit the pistons. He then degreeing his intake centerline came up to 95. What he wants know is how would this motor run or should he just fly cut the pistons so the vavles won't hit???
Thanks Troy B
1964 Crown Coupe 1964 330 Dodge Wagon
Re: intake centerline question [Re: Lynch Rd Runner] #144177
11/01/08 09:23 AM
11/01/08 09:23 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
What is the engine combo & and how big is the cam?
Re: intake centerline question [Re: MoparforLife] #144178
11/01/08 10:04 AM
11/01/08 10:04 AM
OH
OH
440 engine .30 over roller cam pretty sure lift is 678 . I know by seeing down the spark plug hole there is quite a overlap. 850 holley, old aluminum indy single plane, 516 heads made into maxwedge heads and ported.
Re: intake centerline question [Re: Lynch Rd Runner] #144179
11/01/08 11:40 AM
11/01/08 11:40 AM
Are you saying that he adjusted the centerline away from ideal to get enough p/v clearance? (~.100").If so especially since he is in the mockup stage I would have them cut rather than leaving power on the table. You want that short block spot on then you can upgrade further on down the line(good heads) as $$$ permits without haveing to pull(or go back into) the short block.
Re: intake centerline question [Re: RapidRobert] #144180
11/01/08 03:13 PM
11/01/08 03:13 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
More information on the setup would be nice, but it sounds like the pistons will need to be cut, or use a smaller cam?
