Gauge panel to fit stock A-body dash?
#1441734
05/25/13 12:21 PM
05/25/13 12:21 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I'm interested in making a gauge cluster to fit my '72 Dart which would attach where the original instrument panel goes (and keeping the stock dash/pad). I bought the car shell with no wiring at all and am making my own, so compatibility with the stock harness is not an issue. I've never fabricated anything like this. What's the best way to go about it? Mount aluminum sheet over the original plastic cluster? Bend a sheet to fit the opening and discard the original? I have a 3-3/8" Auto Meter speedo and am looking for the matching tach, so those two will be in the center where the old rectangular speedo was. Any tricks, tips, etc. appreciated. Thanks.
Re: Gauge panel to fit stock A-body dash?
[Re: DrCharles]
#1441735
05/25/13 02:40 PM
05/25/13 02:40 PM
Posts: 4,848 Memphis
HemiRick
Memphis
This is a difficult question to answer because we do not know your skillz and tools. This job is a balance between what you can do and what looks decent/ok/great ! Just experiment with the materials you can work with till you come up with something that looks nice.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: MuuMuu101]
#1441737
05/25/13 04:20 PM
05/25/13 04:20 PM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
I made my own out of 3/16" aluminum. I used polished Marine rings for the gauges. used a stock heating pod from a 70 Dart. Stock switches...turn signals, hazards, and e-brake were LEDs
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#1441740
05/25/13 08:59 PM
05/25/13 08:59 PM
Posts: 15,487 Florida
scratchnfotraction
Closeup #1
that looks super slick but the 5 pound key chain is killing the ign switch.
[Re: Scamp408]
#1441744
05/26/13 03:34 PM
05/26/13 03:34 PM
DrCharles
West Plains, MO
I took a stock gauge panel and grinded down the high spots and took a piece of plexi cut to fit and epoxy it in .
I like your idea, but I've found it's easy to crack Plexiglas or Lexan when cutting/drilling... since my last post I was thinking of doing something similar using the original cluster with the center cut out, and a piece 3/32" or 1/8" aluminum plate... trial layout with cardboard template:
I like 2-5/8" gauges for readability especially at high speed, but I never realized how small the usable portion of the cluster is when adding gauges! I'll use a column- or dash-mounted tach instead... got a Sun Super Tach in the junk box...
[Re: DrCharles]
#1441747
05/26/13 07:57 PM
05/26/13 07:57 PM
Pyper70
Athens, Greece
You will find that when you take Lexan and cut out three 2 5/8" holes plus a 4" hole for your speedo, it will become VERY flimsy. Even adding supports on the rear, if you tweak it one way, it may snap. I found some scrap metal cutoff's from a machine shop for 5 bucks and laid a paper template over what I wanted it to look like. It resembles an 71 A-Body Rally Dash. I had one that I traded parts for so I knew my dimensions. The center pod is usually "Performance" meter which I aptly changed to a vacuum gauge. AutoMeter does sell the 4-in-1 gauges here http://autometer.com/cat_gaugedetail.aspx?ref=search&gid=3594 so maybe you could use one of those and a speedo if you want to keep it tidy. I wanted to spread out my instruments across my dash and have each one very visible as I drive. If you want to kick up any gauges, grab some PVC pipe and cut it at the angle you want, You don't want to do more than an eye moment to look down for the reading of the gauge, if you have to crick your neck then it will be annoying as time passes on. My angled necks were from Rex Marine in Riverside (if they are even in business anymore. They weren't cheap though, like $15 a piece but really sets off the dash As for the 5 pounds of keys in my ignition....hahaha...what can I say...a bike lock, 2 keys for the Dart, a 1.5" Plastic Pentastar I stole off of the hood of a Diplomat. Even have a glass breaker handle and a small 8-ball on the end
[Re: DrCharles]
#1441751
06/16/13 10:02 PM
06/16/13 10:02 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I made this for my shorty. I used the factory bezel and cut/fitted a piece of textured ABS from www.tapplastics.com. If you can find a store local to you the prices are better. They can cut it out for you also.. I bought 2 pieces for $10.00. Go with 3/16" or 1/4" for strength..
I am truckless..
