Hard Brake Pedal #1441489
05/24/13 06:47 PM
05/24/13 06:47 PM
Ohio
JT01 Offline OP
JT01  Offline OP
Ohio
I have a 69 Charger and installed a new SBBC brake system its disc on front drums on rear everything is brand new from front to rear including the lines my pedal is very hard to push and only moves just a little bit. I checked the vacuum and it has 16 inches of vacuum Ive put 2 new boosters on it with the same issue.Whats going on here with this thanks for any help.
Re: Hard Brake Pedal [Re: JT01] #1441490
05/24/13 07:39 PM
05/24/13 07:39 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
How much vacuum is the booster seeing?
Is the m/c bore too big?
Re: Hard Brake Pedal [Re: JT01] #1441491
05/24/13 10:16 PM
05/24/13 10:16 PM
I'd check how much clearance you have between the rounded nub on the end of the pushrod coming out of the booster & the bottom of the M/C rear piston (thimble). Want ~.060" or a bit less. Might crack a corner bleeder (either side) on the front then on the rear (seperately) & see if you get a full stroke. Might work the pedal & have a helper see how the front calipers are acting & might take off the rear drums & same deal but just a moderate amt of pedal travel when the rear drums are off so he dont pop the rear wheel cyl pistons out
Re: Hard Brake Pedal [Re: JT01] #1441492
05/25/13 01:57 AM
05/25/13 01:57 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
This is a common problem with SSBC brakes.
You probably need a 15/16" bore master cylinder.
Re: Hard Brake Pedal [Re: DoctorDiff] #1441493
05/25/13 02:03 AM
05/25/13 02:03 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
if you take off the master cyl. from the booster the rod should be adjustable , the rod might be adj. out too far try turning it in and see if that helps.
Re: Hard Brake Pedal [Re: a493demon] #1441494
05/25/13 10:07 AM
05/25/13 10:07 AM
Ohio
JT01 Offline OP
JT01  Offline OP
Ohio
Allready did that never changed anything
Re: Hard Brake Pedal [Re: JT01] #1441495
05/25/13 12:20 PM
05/25/13 12:20 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
What master cylinder are you running?
Re: Hard Brake Pedal [Re: DoctorDiff] #1441496
05/25/13 12:38 PM
05/25/13 12:38 PM
Ohio
JT01 Offline OP
JT01  Offline OP
Ohio
The one that came with the ssbc kit. Should I get a different one.
Re: Hard Brake Pedal [Re: JT01] #1441497
05/25/13 12:54 PM
05/25/13 12:54 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I don't think SSBC provides the correct master cylinder with their brake kits. Measure the bore size to confirm.
You need a 15/16" master for a '73-'75 A-body power disc brake application.
Re: Hard Brake Pedal [Re: DoctorDiff] #1441498
05/25/13 08:02 PM
05/25/13 08:02 PM
Ohio
JT01 Offline OP
JT01  Offline OP
Ohio
You need a 15/16" master for a '73-'75 A-body power disc brake application. [/quote. Where can I get one of these master cylinders and is it a 2 bolt application
Re: Hard Brake Pedal [Re: JT01] #1441499
05/25/13 08:21 PM
05/25/13 08:21 PM
An 89 Dakota 15/16" M/C would be a 2 bolt app. The 73-75 A body 15/16" app would not
Re: Hard Brake Pedal [Re: JT01] #1441500
05/25/13 08:30 PM
05/25/13 08:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Be sure the booster pushrod isn't preventing the rear piston in the MC from fully returning. If the pushrod is adjusted out too far the rear piston won't allow the fluid to return to the reservoir and you'll get a hard pedal.
Re: Hard Brake Pedal [Re: John_Kunkel] #1441501
05/25/13 08:58 PM
05/25/13 08:58 PM
Ohio
JT01 Offline OP
JT01  Offline OP
Ohio
We adjusted the pushrod all the way in and it still has a hard pedal
Re: Hard Brake Pedal [Re: RapidRobert] #1441502
05/25/13 09:06 PM
05/25/13 09:06 PM
Ohio
JT01 Offline OP
JT01  Offline OP
Ohio
Would this M/C have the lines going in on the drivers side
Re: Hard Brake Pedal [Re: JT01] #1441503
05/25/13 09:08 PM
05/25/13 09:08 PM
I would think so but I'm not sure. I'd have your parts house pull it off the shelf & let you know
Re: Hard Brake Pedal [Re: RapidRobert] #1441504
05/25/13 11:52 PM
05/25/13 11:52 PM
Ohio
JT01 Offline OP
JT01  Offline OP
Ohio
Re: Hard Brake Pedal [Re: JT01] #1441505
05/26/13 12:37 PM
05/26/13 12:37 PM
Ohio
JT01 Offline OP
JT01  Offline OP
Ohio
I also found this one and could buy a adapter plate to make it work. Let me know guys if any of the se I listed will work thanks. http://www.jegs.com/i/Right+Stuff/965/DBMC15/10002/-1
Re: Hard Brake Pedal [Re: JT01] #1441506
05/26/13 02:57 PM
05/26/13 02:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You still need to make sure the rear piston is returning. With the lid off the MC, have somebody gently depress the brake peddle and look for a burble of fluid on the fluid surface in rear reservoir....if no burble the piston isn't fully returning.
Re: Hard Brake Pedal [Re: JT01] #1441507
05/26/13 03:49 PM
05/26/13 03:49 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Loosen the master cylinder mounting nuts. If the unit springs forward, the input rod must be shortened.
I can provide a new, aluminum 15/16" bore master with billet adapter for $100, or a new, 4-bolt iron version for $75.
