How to tell a real e body Hemi kframe from a repop? #144126
10/31/08 10:48 PM
10/31/08 10:48 PM
PA
P
plumcrazycuda Offline OP
P
PA
Can anyone tell me how to tell?
Re: How to tell a real e body Hemi kframe from a repop? [Re: plumcrazycuda] #144127
10/31/08 11:58 PM
10/31/08 11:58 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
between the 2 that I have seen,,, the original had crappy welds
I am truckless..
Re: How to tell a real e body Hemi kframe from a repop? [Re: 340SHORTY] #144128
11/01/08 12:26 AM
11/01/08 12:26 AM
AndyF Online content
AndyF  Online Content
That is what I was going to say! Whoever did the welding on the factory K frames didn't know how to weld. They must have hauled in drunk guys from under the bridges and told them to weld K frames.
Re: How to tell a real e body Hemi kframe from a repop? [Re: AndyF] #144129
11/01/08 08:49 AM
11/01/08 08:49 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
otherwise I agree on the welds , I have a repop hemi K , it's BEAUTIFUL .
Re: How to tell a real e body Hemi kframe from a repop? [Re: AndyF] #144130
11/01/08 09:23 AM
11/01/08 09:23 AM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
But first they practiced on floor pans.
Steve
www.clarkclassic.com
Re: How to tell a real e body Hemi kframe from a repop? [Re: BarrsRestoration] #144131
11/01/08 05:26 PM
11/01/08 05:26 PM
PA
P
P
PA
Any other markings on a OEM one beside bad welding job?
Re: How to tell a real e body Hemi kframe from a repop? [Re: plumcrazycuda] #144132
11/01/08 06:51 PM
11/01/08 06:51 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If you really want to spot a reproduction examine the welded on motor mount areas, look at the sides of the fromed steel parts that would be added to form the motor mount bosses. These pieces are generally reproduced using modern day manufacturing techniques such as plasma, laser, or water jet cutting which makes the edges look different that originals which were stamped using dies. The edges of the die stamped pieces generally have a pinch line along the center wher they sheared in the stamping process, the modern edges look more serrated like the edges of a dime or a quarter. This same method can be used to spot many modern reproduction steel parts such as intake manifold brackets and motor mounts.
