Speedo cable lube? #144091
10/31/08 09:26 PM
10/31/08 09:26 PM
Batavia,Ohio,
Moparmick Offline OP
Batavia,Ohio,
Whats the best thing to use for lube on speedo cable, 71 charger? Mick
Re: Speedo cable lube? [Re: Moparmick] #144092
10/31/08 09:44 PM
10/31/08 09:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Graphite.
Re: Speedo cable lube? [Re: stumpy] #144093
10/31/08 09:49 PM
10/31/08 09:49 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Powdered graphite. Comes as speedo cable lube available at most parts stores.
Re: Speedo cable lube? [Re: Moparmick] #144094
10/31/08 09:53 PM
10/31/08 09:53 PM
Charlotte NC
DCI Offline
DCI  Offline
Charlotte NC
I have used graphite with success. I had one that would not smooth out so I took the cable out and used white lithium grease on and that fixed it.
"Turbo will be easiest, and at the HP level will also be easiest on parts. Spend the money to do it right, and you can build a 500 HP street motor that will live a long and happy life, and probably with a very basic short block." Those words must have left a bad taste in his mouth!
Re: Speedo cable lube? [Re: Moparmick] #144095
10/31/08 10:05 PM
10/31/08 10:05 PM
IMGTX Offline
IMGTX  Offline
I use a mixture of graphite and transmission fluid. I remove the insert of the cable at the speedo end and spray some graphite and tranny fluid in the end and fish the cable the insert back in while adding fluid and graphite as needed.
Works for me.
