What Valve Cover Gaskets with Fabed V/C's #1440647
05/22/13 08:49 PM
05/22/13 08:49 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
The time has come to install my new MP aluminum 452 heads and the 25 year old Moroso valve covers are going away. I got a set of fabicated valve covers to go on it and was wondering what gaskets work best with these ? I have always used the rubber coated fiber gaskets with steel covers, but the fabed ones do not have the lip on the edge or the slots for the tabs on the gaskets. Thanks for the input.
1969 Super Bee High School car I got back 2004 Ram 2500
Re: What Valve Cover Gaskets with Fabed V/C's [Re: runnerrt] #1440648
05/22/13 10:21 PM
05/22/13 10:21 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Cut the tabs off
Re: What Valve Cover Gaskets with Fabed V/C's [Re: runnerrt] #1440649
05/22/13 10:26 PM
05/22/13 10:26 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I recently switched to Morosos. They aren't cheap at $40, but they maintain their shape, so those locating tabs you mentioned which are on stock replacements, aren't necessary.
Before that I was using black rubber gaskets, not sure where I got them. They had the tabs, and I've been using them with fabbed covers for years.. they were starting to get a little tired, so I splurged for the Morosos.
They both seal fine. I think the only advantage of the Morosos is, because the shape is fixed, they are quicker/easier to put back. But if you don't plan on R/R them in a hurry, the black rubber ones are great (but I don't know where to get a set). I probably would have gone with a new set of the black rubber ones if I knew where to get them.
Re: What Valve Cover Gaskets with Fabed V/C's [Re: 76dodgeboy] #1440650
05/22/13 10:29 PM
05/22/13 10:29 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Cut the tabs off
He could, but I think they can help.. since they stuck out, it was easier for me glance at the tabs to make sure the gasket was aligned properly before tightening. If the gasket keeps its shape like the morosos, no problem tabs or no tabs.
Re: What Valve Cover Gaskets with Fabed V/C's [Re: Exit1965] #1440651
05/23/13 04:08 AM
05/23/13 04:08 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I will only use the Fel-Pro high temp rubber coated fiber gaskets.
They are "me proof" and dont crush. I also use Indian Head to glue to gasket to the valve cover after prepping the cover. Then let the gasket and sealer set overnight before installing on the engine.
I also prefer to use the Indian Head to glue the cover and gasket to the head. And again let it set overnight, or as long as possible before snugging down the bolts.
Sure it takes some extra time, and yes its a PITA to remove the valve covers. BUT I have NEVER had a leaking valve cover since doing them this way about 15yrs ago.
And for the guys that say why do that, its so hard to remove the valve cover. I say, how often do you need to remove a valve cover on a hydraulic lifter motor? There is no need to service anything under the cover unless you over rev and bend a pushrod, or pop a lifter.
I dont mind the extra prep time, and the extra service time knowing that even if a bolt or two ever works loose I still have no leaks.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: What Valve Cover Gaskets with Fabed V/C's [Re: hp383] #1440652
05/23/13 02:57 PM
05/23/13 02:57 PM
Lakewood, Colorado
runnerrt Offline OP
runnerrt  Offline OP
Lakewood, Colorado
My main concernwas them keeping their shape during install. I may try the Moroso's later as the budget is tapped at the moment. Looks like the rubber coated fiber is the ticket for now. Thanks again for the input.
