Re: fresh 340 cam plug leaking
[Re: Neil]
#144071
11/01/08 08:46 AM
11/01/08 08:46 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
As long as its not loose, clean it well and put a good bead of ultra RTV in around the edge.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: 451Mopar]
#144078
11/02/08 11:46 AM
11/02/08 11:46 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I drill a small hole or two, screw in a couple screws, and pry them out. The filings can be removed with a magnet and they will not travel anywhere. I would goop it. It's a pain in the behind if it leaks again. Also, I hate that particular design... I use the one under it that goes in and gets hit in the center to expand it. Use a little grey silicone on the outside edge, and smooth it around the seam after it's expanded, and it's done.
