carb spacers #144052
10/31/08 07:48 PM
10/31/08 07:48 PM
rbdy Offline OP
rbdy  Offline OP
I have a mild rebuild on a 65 Plymouth 383 HP, auto/3:55 gear,Eddy performer intake, question: are the carb spacers for top end performance only or would one help for average cruzin???
thanks guys
Re: carb spacers [Re: rbdy] #144053
10/31/08 08:00 PM
10/31/08 08:00 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
4 hole may help your bottom and the open spacer usually will add to the top. Not a set in stone thing but usually.
Re: carb spacers [Re: MoparforLife] #144054
10/31/08 09:15 PM
10/31/08 09:15 PM
Outside
thedriver Offline
thedriver  Offline
Outside
and sometimes an open spacer will make a handfull more hp on the topend, but will take away tork on the bottom.....which, unless you have a stroker, can have negative effects on et, as opposed to not runnin a spacer at all.
1973 challenger
Dana. 4 speed. Low deck.
