Post deleted by moparts #144020
10/31/08 05:03 PM
10/31/08 05:03 PM
Anonymous OP
Anonymous OP
Re: 440 backfiring issue #144021
10/31/08 05:17 PM
10/31/08 05:17 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If it's a repetative bunch of popping, it could have a round cam lobe.
Re: 440 backfiring issue #144022
10/31/08 09:32 PM
10/31/08 09:32 PM
CJV5314 Offline
CJV5314  Offline
I had that happen on my 440. Was running an eldelbrock aluminum intake with a carter 4-bbl.
when I switched over to a new six pack setup, I noticed that the bolts were loose on the 4-bbl intake.oops! I made sure that I used a new gasket and tightened it up the second go around. No trouble with the new setup. Lean condition caused by loose intake?
Re: 440 backfiring issue [Re: CJV5314] #144023
10/31/08 09:39 PM
10/31/08 09:39 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Check your firing order and plug wire orientation & routing..
Re: 440 backfiring issue #144024
11/01/08 10:25 AM
11/01/08 10:25 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I have had the same problem more than once. every time, it was a wiped cam lobe.
This is the land of the free because of the brave
Re: 440 backfiring issue #144025
11/01/08 12:18 PM
11/01/08 12:18 PM
plugs/wires/timing/rotor phasing
Re: 440 backfiring issue #144026
11/02/08 03:17 AM
11/02/08 03:17 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If it only does it under acceleartion I would think it is a lean air/fuel mixture mis-fire.
Check for vacuum leaks, and maybe the outer carbs are opening too quickly or may be too lean?
