Re: 72-80 Leaf spring swap, m880 springs [Re: hp383] #1440136
05/31/13 02:47 PM
05/31/13 02:47 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
They aren't even 4".
Re: 72-80 Leaf spring swap, m880 springs [Re: 76dodgeboy] #1440137
05/31/13 04:15 PM
05/31/13 04:15 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
yeah the block on my m880 is like 3" or maybe 3.5" i forget exactly.
mine does have a pretty aggressive rake with factory springs all around.
my truck has the factory rearend in it, dana60, so the axle tubes/spring perches might make the height of a 1/2 ton truck a little less than on an actual m880.
i still think you'll end up with some rake, it'll be fine though. get the rear together then decide what you want to do with the front.
btw there should be a metal plate on the dash in the m880 that list the weight ratings and all that stuff.
Re: 72-80 Leaf spring swap, m880 springs [Re: krautrock] #1440138
06/01/13 12:08 AM
06/01/13 12:08 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
if you use the m880 block
There is no M880 block. A Special M880 is just a camo fart.
Re: 72-80 Leaf spring swap, m880 springs [Re: NITROUSN] #1440139
06/01/13 10:31 AM
06/01/13 10:31 AM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i used that term to describe the block that should be on the m880 he's pulling the suspension parts from (because it's possible his truck might have a different block, who know...)
i didn't imply that the m880 has a "special" block or anything
Re: 72-80 Leaf spring swap, m880 springs [Re: krautrock] #1440140
06/02/13 05:35 PM
06/02/13 05:35 PM
Portland , Oregon, United Stat...
smokes Offline OP
smokes  Offline OP
Nice, I will have to go check to see if it is still there. I know I glanced at the dash and saw that the plate on the center left was missing. Hopefully that is not the one that has all the info. I think I might just throw the rears on and see how they sit before I redo the front springs.
Anyone know if a company makes urethane leaf spring bushings for the front or rear of these trucks? The m880 ones look ok but I would like to put in new ones before installation.
Looking for a clean w150 or w200 **72-80 body style In the Pacific Northwest**
Re: 72-80 Leaf spring swap, m880 springs [Re: smokes] #1440141
06/02/13 05:39 PM
06/02/13 05:39 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
most of the lift kit companies also sell the spring eye bushings in urethane.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 72-80 Leaf spring swap, m880 springs [Re: hp383] #1440142
06/02/13 07:17 PM
06/02/13 07:17 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Again that plate is just how the Military rated it. Its no different than a Powerwagon of the same yr. Its just a 3/4 ton that the military called a 5/4 or whatever they rated them. No heavier duty than the savilian Powerwagons
