Street car dana carrier...which one #1440105
05/21/13 10:23 PM
05/21/13 10:23 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
Dana 60...4.56 for street/strip. Which is best for use with four speed. I have read some people not liking the locker with manual trans, and have seen some negatives to the traclok. Indy headed 440. 600ish hp. Thanks for all advise. Axles are getting made so 30 or 35 spline.
Re: Street car dana carrier...which one [Re: Tommy383] #1440106
05/21/13 10:49 PM
05/21/13 10:49 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
You want a Dana Power Loc. I have one in my Dana 60 and it works great,in fact it's been working since 1982 with no problems.
Nautilus Racing-
Re: Street car dana carrier...which one [Re: Tommy383] #1440107
05/21/13 10:51 PM
05/21/13 10:51 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
At that power level and torque I would strongly suggest the 35 spline Power-Lock unit I don't think they are making them new anymore so you better grab one soon.
I run a spool
Gus
64 Plymouth Savoy
Dana 60
Re: Street car dana carrier...which one [Re: Chris2581] #1440108
05/21/13 10:51 PM
05/21/13 10:51 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
Can they be bought new. I've read nothing but good things about them but cannot find one new anywhere.
Re: Street car dana carrier...which one [Re: Tommy383] #1440109
05/21/13 10:52 PM
05/21/13 10:52 PM
NC
Tommy383 Offline OP
Tommy383  Offline OP
NC
I was typing that while you posted. Lol. If I was to go new what could I get that is compatible to the power lock
Re: Street car dana carrier...which one [Re: Tommy383] #1440110
05/21/13 11:19 PM
05/21/13 11:19 PM
SE PA
Yellow Fever Offline
SE PA
Re: Street car dana carrier...which one [Re: Yellow Fever] #1440111
05/21/13 11:21 PM
05/21/13 11:21 PM
SE PA
SE PA
Re: Street car dana carrier...which one [Re: Yellow Fever] #1440112
05/22/13 11:49 AM
05/22/13 11:49 AM
dogdays Offline
dogdays  Offline
www.doctordiff.com will give you the straight scoop on what's available.
If a Truetrac is available for that, it'd be my #1 choice.
r.
Re: Street car dana carrier...which one [Re: dogdays] #1440113
05/22/13 12:58 PM
05/22/13 12:58 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
If you go with a dana 70 from a truck, your chances of getting a power lock a good with 35 splines and it has a 10.5" ring gear. The housing is the same size as a 60. Dutchman can narrow a truck housing and put the ford ends (disc brakes for cheap) on for around 375 including shipping. Shafts are another 400 in either 1541 or 4340. I did the Jana 76, if I was to do it again, I would have bought the 70 housing first. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Street car dana carrier...which one [Re: dogdays] #1440114
05/22/13 06:30 PM
05/22/13 06:30 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
r.
I bought my Strange 60 from Dr Diff. He recommended the truetrac and 373 gear with my 645hp hemi it works great on the street.
Re: Street car dana carrier...which one [Re: fourgearsavoy] #1440115
05/22/13 07:07 PM
05/22/13 07:07 PM
fresno ca
mikeysmopars Offline
fresno ca
think i have one, Came from a 1979 direct connection dana 60. Its 35 spline and in great shape!
PM Me
Founder and CEO of the Central Valley Mopar Drag Pack
