Re: Tach is all screwy.
[Re: abloch]
#1440051
05/21/13 09:34 PM
05/21/13 09:34 PM
RapidRobert
More info, How is the tach reading backwards? Might power the tach hot lead directly to the batt positive post (or starter relay batt stud) just for a test. On the dist leads, the eng (timing) runs good except for the tach issue?). I would check/clean all (related) connections for starters.
