New turn signal switch is acting weird - long #1439503
05/20/13 01:44 PM
05/20/13 01:44 PM
Itasca, Texas
Mad_Scientist Offline OP
Itasca, Texas
I installed a new turn signal switch on my Bee last year and I thought it was working fine. However, I just noticed an issue where if I turn on the blinker, turn it off AND I don't get the stalk centered enough, the blinker stays on. The dash doesn't show that the blinker is still on, so I just cruise with it on for miles. When the car is not running, you can hear the relay clicking but the dash isn't lit up indicating this. The issue only happens when the stalk itself is not centered. Also, when turning a corner, it correctly snaps the stalk back to center and there is no issue. Is there anything I can do to fix this, or do I have to order a new signal switch?
69 Super Bee 440 5-speed
70 Dart Swinger 340 4-speed
69 Camaro SS 396 4-speed
66 Cutlass Convertilbe
70 Judge Ram Air III 4-speed
68 F-100 SWB
Re: New turn signal switch is acting weird - long [Re: Mad_Scientist] #1439504
05/20/13 02:52 PM
05/20/13 02:52 PM
oklahoma
69suprbee Offline
69suprbee  Offline
oklahoma
had the same problem with my 69 bee.i had tightened the switch too much.once i loosened it back up it snaps to the middle just fine.
Re: New turn signal switch is acting weird - long [Re: 69suprbee] #1439505
05/20/13 04:01 PM
05/20/13 04:01 PM
Itasca, Texas
Itasca, Texas
That makes sense. I'll loosen it up. Thanks for helping me out.
68 F-100 SWB
