Re: Pre 65 8 3/4 questions
[Re: SLOW67]
#1439063
05/19/13 09:14 PM
05/19/13 09:14 PM
Posts: 1,285 okla.
sam64
okla.
no need to to git rid of the housing it will accept later axles. and yes the center sections interchange.
[Re: SLOW67]
#1439064
05/19/13 09:16 PM
05/19/13 09:16 PM
Posts: 52,972 Romeo MI
MR_P_BODY
It'll bolt in.. dont know which one you have but if you get the last 3 numbers off it we would know more.. but the alum center is based on the straight 1 3/4 pinion which is the old one
[Re: SLOW67]
#1439066
05/19/13 09:49 PM
05/19/13 09:49 PM
MR_P_BODY
I'll try to get some numbers off it tomorrow. So if I have a set of later axles, if they are the same length, I can slide them in this housing?
Depends if you have stock splines and if the center is
[Re: sam64]
#1439067
05/19/13 10:04 PM
05/19/13 10:04 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I thought you had to change the ends of the axle tubes when changing from a tapered/keyed axle to the 65 and later flanged style?
Kevin
[Re: Twostick]
#1439068
05/19/13 10:06 PM
05/19/13 10:06 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Yes you do, that is why I put the Dana in my 64 Polara.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Twostick]
#1439069
05/19/13 10:15 PM
05/19/13 10:15 PM
MR_P_BODY
Kevin
Anyone that raced the old stuff with the tappered axles got rid of them... when I raced my 62 out on Woodward YEARS ago I had a pile of keys in the glove box.. if it hooked good they sheared off... I finally put a newer B-body 8 3/4 in it
[Re: SLOW67]
#1439071
05/19/13 10:23 PM
05/19/13 10:23 PM
Polarapete
Graham, WA
Heavy cars and/or overpowered cars with sticky tires need the beef of the best 8%3/4 parts or the Dana 60. In my case the easiest and cheapest solution was to narrow a Dana 60, buy new 30 spline axles, use Mopar ends and 10" brakes. If you build a lighter car and don't abuse it a 8&3/4 will last just fine.
[Re: SLOW67]
#1439073
05/19/13 10:43 PM
05/19/13 10:43 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Somebody installing a 8.75 pre 65 tapered housing into a 74 for racing is rather strange IMO in the first place, any other surprises?
[Re: jcc]
#1439074
05/19/13 11:06 PM
05/19/13 11:06 PM
Posts: 928 NC
SLOW67
NC
Not so far other then it being stripped out to start building a drag car. Luckly he kept and labeled all the interior pieces. This is a numbers car minus the rearend, but whats weird is it has a flat mount k member in it
