Re: Oil Pan bolt stripped into the timing cover, fix?
[Re: cudabitten]
#1439034
05/19/13 07:47 PM
05/19/13 07:47 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
If it's an outer bolt you can use a longer bolt & use a nut...
[Re: cudabitten]
#1439035
05/19/13 07:47 PM
05/19/13 07:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Pull the cover and helicoil it.
Some might suggest a larger diameter bolt and rethreading the cover, but that's a poor choice, imo.
[Re: 1_WILD_RT]
#1439036
05/19/13 07:53 PM
05/19/13 07:53 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
That would be the quick and easy "git er done" fix!
[Re: cudabitten]
#1439038
05/19/13 08:55 PM
05/19/13 08:55 PM
Posts: 15,487 Florida
scratchnfotraction
you have come this far so dont goober it up on the hickabilly bolt/nut trick. pull the cover or the pan and put a helicoil insert into the t-cover,make sure to remove the tang on the coil before running the bolt thru it. I have a cover that both holes have been done this way for a long while now. my one SB alum intake has had a helicoil put into every bolt hole with threds on it. fix it once and be done with it. you dont want a goober nut/bolt on a nice painted engine.
[Re: scratchnfotraction]
#1439039
05/19/13 10:29 PM
05/19/13 10:29 PM
Supercuda
About to go away
About to go away
up yours
I usually end up helicoiling any aluminum threads on my engines. I spent the money for the kits years ago and it's paid for itself more than once.
Just cheap penny pinching to built it that way by the manufacturers.
[Re: cudabitten]
#1439045
05/20/13 12:22 PM
05/20/13 12:22 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Ok, you guys are right. I probably would have put the nut on there and looked at it for 20 min, then jumped in my car to find a helicoil kit. Plus engine is upside down on stand with only the 4 bottom bolts holding the timing cover on. I can have it off in less than a minute.
If ythe engine is still on the stand fixing it the right way makes sense , if it were in the car and you needed to get it fixed for the morning commute then the longer bolt and nut is the way to go .
I also helicoil alum threads I know will come apart more than once in a lifetime. I have done a few transmission jobs that have had the pan, pump and valvebody holes all helicoiled while I have it on the bench.
[Re: babarracuda]
#1439048
05/21/13 11:44 AM
05/21/13 11:44 AM
JohnRR
Isn't a helicoil longer than the width of the cover hole? I guess you could put in the heicoil with permanent thread bonder and after it dries, cut off the excess that sticks out on the top. A long bolt and nut seems the simplest fix to me.
Helicoils come in a variety of lengths, you can buy a KIT that is a little more costly than the Ace hardware kit that has 3 different length coils .
Or you can trim a as many turns off as necessary BEFORE installing one by using a dremel with a tiny cutoff wheel , I've done it multiple times.
