3/8 sleeve for Harland sharp rockers w/pic #1438943
05/19/13 04:43 PM
05/19/13 04:43 PM
ont,canada
mopartuner Offline OP
ont,canada
I am making sleeves for my 5/16 bolts for Harland sharp rocker arms.I am using fairly light spring so I thought this will be the simple way to go.I made the sleeves out of 3/8 brake line and I cut them just below the top of the rocker shaft,look ok?
410 pump gas solis flat tappet cam 10.95 so far
Re: 3/8 sleeve for Harland sharp rockers w/pic [Re: mopartuner] #1438944
05/19/13 05:56 PM
05/19/13 05:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A few question for you... first... how is the oil gonna
get in the shafts.. next whats the spring pressure open..
I did this years ago waiting on my W2 heads... with
the springs I had it didnt last 1 night.. the bolts broke...
to be honest its easier to drill and tap the heads and
its better
Re: 3/8 sleeve for Harland sharp rockers w/pic [Re: MR_P_BODY] #1438945
05/19/13 06:19 PM
05/19/13 06:19 PM
ont,canada
ont,canada
its better
I am using standard oiling.The sleeve doesn't totally fill the hole where the oil comes up.The spring pressure will be 380 lbs open.I don't have a problem tapping the heads but I would also have to drill out my MP hold downs and mill the countersunk part and I don't really have the equipment for that.
Re: 3/8 sleeve for Harland sharp rockers w/pic [Re: mopartuner] #1438946
05/19/13 06:36 PM
05/19/13 06:36 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
just me but I would drill and tap the heads and use studs instead of bolts
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 3/8 sleeve for Harland sharp rockers w/pic [Re: mopartuner] #1438947
05/19/13 08:24 PM
05/19/13 08:24 PM
wv
Dartcuda Offline
Dartcuda  Offline
wv
Sharp makes 3/8" x 5/16" spacers
