Re: Front Spoilers...
[Re: Duner]
#1438674
05/31/13 10:22 PM
05/31/13 10:22 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Mopar to the bone!!!
[Re: OzHemi]
#1438675
05/31/13 10:35 PM
05/31/13 10:35 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
Interesting, which is why i went with this - I wanted more function than looks - its a 67 camaro rear spoiler and would have been a perfect fit if it was about 1 1/2" - 2" longer
If you were looking for more width, a '69 Camaro spoiler is wider than a '67/8 one, incase you didn't know..
really? I did not know this - thanks for the info
[Re: BigBlockMopar]
#1438676
06/01/13 08:49 PM
06/01/13 08:49 PM
Posts: 22,739 Bitopia
jcc
Bitopia
I was looking for some windtunnel-testing videoclips of front and rearspoilers and such, when I stumbled on a number of interesting articles on Autospeed.com about spoiler and improving 'under car' airflow;
Part 1 http://www.autospeed.com/cms/A_2455/article.html
Part 2 http://www.autospeed.com/cms/A_2456/article.html
Earlier articles:
http://www.autospeed.com/cms/article.html?&A=109937
And...
Undertrays, Spoilers & Bonnet Vents, Part 1 http://www.autospeed.com/cms/A_2159/article.html
Undertrays, Spoilers & Bonnet Vents, Part 2 http://www.autospeed.com/cms/A_2160/article.html?popularArticle
Those are useful articles, thanks for posting, my biggest takeaway, without any testing, little can be learned, as aero "common sense" is still largely black magic, IMO.
[Re: jcc]
#1438677
06/01/13 09:33 PM
06/01/13 09:33 PM
jcc
Bitopia
In the 4th link BigBlock posted it refers to a air pressure differential gauge magnehelic, that seems useful for us backyard aero wannabes. They seem readily available and in the under $125 range. Anybody have any real world experience with these gauges? Like, wouldn't a -2.5 to +2.5" of water be a better choice? Is That enough range? How sensitive are readings to how pressure tube opening is oriented? Where on a car is the reference pressure obtained? Inside the car would seem rather variable, by speed, windows up or down, defroster on off, etc Is an analog better then the slightly more costly digital gauge? This is the page that caught me eye. http://www.dwyer-inst.com/Product/Pressure/DifferentialPressure/Gages/SeriesDM-1000/Ordering
[Re: Skeptic]
#1438679
06/03/13 06:44 AM
06/03/13 06:44 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
I 'thought' was able to cheaply fab up a front spoiler for my Dart. Just for kicks, but I found I got my butt kicked by 'geometry' here a bit in the progress. I went to our local HomeDepot and grabbed a nice large cement bucket. These things here are made of very sturdy, but unbreakable plastic. Perfect for possible groundscraping once in a while I thought. Once in the garage I started cutting the reinforced top edge and 4-5" down off it. Also made pie-cuts in the lip to straighten out the curvature. But then I hit a geometric snag. Because of the taper of the bucket, the now 'straightened out' strip, was still curved along it's entire length when flattened out... Duh... ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Also the curvature was the wrongway around for it to even remotely fit. So I cut another strip, but this time from the bottom of the bucket and did a mockup on the car. Secured it with the center valance-bolt in the middle and a number of tie-raps towards the edges. Not happy about how quickly the strip curves upwards behind the valance, I'm now looking for a 'real' spoiler. Usually, my first attempt at making something from scratch is pretty much shoddy at best, so with that knowledge I always have better hopes for the second attempt...! ![](/ubbthreads/images/graemlins/shock.gif) ![](http://img.photobucket.com/albums/v628/BigBlockMopar/1973DodgeDart/IMG_2717crop_zps588c1f49.jpg) ![](http://img.photobucket.com/albums/v628/BigBlockMopar/1973DodgeDart/IMG_2718crop_zps371febad.jpg)
[Re: BigBlockMopar]
#1438680
06/03/13 03:11 PM
06/03/13 03:11 PM
dangina
I think I'm more blown away at the fact they have a home depot in the netherlands!
[Re: dangina]
#1438681
06/03/13 06:05 PM
06/03/13 06:05 PM
BigBlockMopar
The Netherlands
No we don't, that's why I said 'our local' HD. Had I said 'Gamma' or 'Karwei', as these shops are named here, no-one would have known what I was talking about. ![](/ubbthreads/images/graemlins/biggrin.gif) I think I've located a suitable spoiler. Will probably be able to pick it up this saturday. It's a brand new spoiler, for an '81 Mercedes. My guess is it will be very close in size to the Dart's width. ![](http://img.photobucket.com/albums/v628/BigBlockMopar/1973DodgeDart/SpoilerMercedes1_zpse197b40a.jpg)
[Re: dangina]
#1438682
06/04/13 08:13 PM
06/04/13 08:13 PM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
If you want to get tricky and spend a bit more money, why not get two, and fab a longer one from both?
[Re: BigBlockMopar]
#1438683
06/04/13 09:09 PM
06/04/13 09:09 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
What is the model of Benz, or part number?
[Re: Pale_Roader]
#1438686
06/06/13 03:51 PM
06/06/13 03:51 PM
dangina
just found out from the camaro guys that the 69 is about 1 1/2" longer and same bolt pattern, so I'm gonna pick one up, I'd rather buy something off the shelf than to modify one, that way if something happened to it, I can just buy another one!
[Re: BigBlockMopar]
#1438689
06/09/13 09:45 PM
06/09/13 09:45 PM
jcc
Bitopia
I like it, nice adaption, would it maybe be easier to modify a cheap run of the mill fiberglass lower valance to fit the plastic spoiler, rather then the other way around, and maybe have a better aero solution as a result?
