Well got to run Irwindale last night.But it didn't run anywhere like normal.I figured with new converter and trans it would run faster,but all it could muster was a 6.65 with a 1.7 60 ft.Never did get better then a 1.68 in all the runs.All were @106-107.I had the caltracs touching on driver side,and preloaded two flats on passenger with shocks set at 2 first,then 5,ending on 6.At launch it would spin,hook,then spin them slightly in second.I actually left in second once by accident and ran the second fastest time that night.Drag radials were set at 18lbs.Any ideas.....?It was running low 10's last time out and seemed to hook better with less converter and carb.Drag radials are a couple years old.Thanks guys.
