More 225 Questions #1437787
05/16/13 10:34 PM
05/16/13 10:34 PM
McGregor,Iowa 52157
500ciDuster Offline OP
McGregor,Iowa 52157
I have a 1974 slant that is missing the damper bolt but has threads, did they ever go without like a chiivy?
If I'm setting the lifters cold cuz the engine is out right now what is the cold lash since everything bit of info says set them hot?
Mitch
Re: More 225 Questions [Re: 500ciDuster] #1437788
05/16/13 11:03 PM
05/16/13 11:03 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
There is no bolt. You can use a small block one if you want to have one.
I always set them cold. .011 on the intakes and .021 on the exhaust.
Some guys get all up in arms about setting them cold. I always invite them to set them running on my motor with the .560" lift cam in it.
It's a Slant, not a Ferrari.
Re: More 225 Questions [Re: slantzilla] #1437789
05/16/13 11:11 PM
05/16/13 11:11 PM
McGregor,Iowa 52157
McGregor,Iowa 52157
Thanx again, I have another 225 that is a 1982-3 that has a bolt so I was curious.
Re: More 225 Questions [Re: slantzilla] #1437790
05/16/13 11:12 PM
05/16/13 11:12 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
Setting the lash was a pain with it running even with the erson 270 cam that was in mine!
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: More 225 Questions [Re: 500ciDuster] #1437791
05/17/13 11:22 AM
05/17/13 11:22 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Like a lot of things Ma Mopar did, the bolt seems to be random. Some have it, most don't.
I put one in for the ease of turning the motor over with a wrench.
