Intake and carb selection #1437238
05/16/13 04:06 AM
05/16/13 04:06 AM
Poplar Bluff, Missouri
S&J Butler Offline OP
I have a 70 Challenger with a 73 340 in it. The motor is basically stock with the exception of a slightly larger cam (don't exactly know what size) and headers. The car is auto with a 4:10 rear. I am thinking of upgrading to a performer rpm air gap intake and a new carb (has a stock intake and Holley 750 vac on it now).My first question is with the minor engine mods is the intake upgrade worth the cost? My second question is what carb should I run with this combo? (I prefer Holley)
Thanks for any input.
1970 Challenger
1973 Satellite 400
1974 Barracuda
1988 D-150 (LE-150) SWB
2010 Crew cab Hemi Ram
2019 Crew cab Hemi Ram
Re: Intake and carb selection [Re: S&J Butler] #1437239
05/16/13 04:37 PM
05/16/13 04:37 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
how does it run with the set you have now? if it aint broke dont fix it!
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Intake and carb selection [Re: S&J Butler] #1437240
05/16/13 05:13 PM
05/16/13 05:13 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I think that intake would be a great upgrade. the 750 Holley vac is a good carb rebuild it and taylor the secondary spring to open to your liking and make sure the diaphragm is sealed and not perforated and is functioning properly!
Re: Intake and carb selection [Re: S&J Butler] #1437241
05/16/13 06:20 PM
05/16/13 06:20 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Hard to improve on what you have now.
Sheldon
Re: Intake and carb selection [Re: S&J Butler] #1437242
05/16/13 09:14 PM
05/16/13 09:14 PM
Central NC
gch Offline
gch  Offline
Central NC
rpm intake is worth a few ponies.Even more so with 4.10's sa you will be in a higher rpm range more frequently.Carb is perfect.
Re: Intake and carb selection [Re: gch] #1437243
05/17/13 11:47 AM
05/17/13 11:47 AM
dogdays Offline
dogdays  Offline
For a 340 if you waant a new carb I'd suggest a 670 Street Avenger.
It'll run great right out of the box.
Or, you could put a metering block in the back and keep your 750.
R.
Re: Intake and carb selection [Re: dogdays] #1437244
05/20/13 12:42 AM
05/20/13 12:42 AM
Hey what intake gaskets would you guys use with this intake and a stock head?
1970 Challenger
1973 Satellite 400
1974 Barracuda
