Re: MSD 6 AL ign question Ballast resistor or not
[Re: dynamite]
#1436902
05/15/13 05:00 PM
05/15/13 05:00 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
no ballast resistor with msd box..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: dynamite]
#1436903
05/15/13 05:44 PM
05/15/13 05:44 PM
Posts: 26,008 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You don't need the ballast but you should hook the wires on both sides of the ballast together and use them to power the small red wire on the MSD.
[Re: Gavin]
#1436905
05/17/13 01:36 PM
05/17/13 01:36 PM
Posts: 21,086 Niles , Ohio
therocks
Niles , Ohio
You can solder a heavy wire in the back of the ballast also.Looks stock but is direct.Rocky
Chrysler Firepower
[Re: therocks]
#1436907
05/17/13 05:04 PM
05/17/13 05:04 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
That's what I did on my friend's '71 Challenger, works like a charm. OEM appearance, MSD performance.......
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#1436908
05/18/13 07:20 AM
05/18/13 07:20 AM
therocks
Niles , Ohio
Mark mine runs thru the ballast on the 65.Been that way for over 10 years now.Never a problem.I do have a new ballast with soldered wire to replace it when it finally dies.Rocky
Chrysler Firepower
[Re: markz528]
#1436909
05/20/13 08:24 AM
05/20/13 08:24 AM
Posts: 1,756 London, England
Gavin
London, England
Correct, the MSD unit does not NEED a ballast resistor. However it can be used with one if you want to,
Don't agree with that. My 6AL2 wouldn't run right and the first thing MSD asked was does it have a ballast resistor. They said eliminate it and I did. Problem went away. Basically with the resistor that car would not run.
So you had a problem with your ballast resistor....or maybe it is different for the 6AL2? This question has been discussed over and over through the years and always arrives eventually at the same answer. MSD have confirmed it too. It gets confusing cos all they usually say is 'you don't need a ballast'. But if you want to use one....it will make no difference to the functioning of the MSD 6AL .
