Re: Dyno 440 in a few days.
[Re: 70ucode]
#1436417
05/14/13 10:02 PM
05/14/13 10:02 PM
Posts: 903 Saskatchewan, Canada
cudabin
Sounds pretty cool... I am also using a Mr Six Pack Cam on my 440 build underway right now and will also dyno it, so we can compare results. did you flow the heads after pocket porting?? Cheers, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: 70ucode]
#1436420
05/15/13 11:21 AM
05/15/13 11:21 AM
cudabin
Yes, it is the original numbers matching engine for my V code Super Bee, so I finally decided to go right through it and upgrade everything possible while staying as stock as possible... My 906's used to flow about 236 cfm after a decent valve job and mild pocket porting. Going to try and improve mid lift flow a bit more, as the Mr Six pack cam won't open the valves past .500" anyways... Keep us posted! Arnie
[Re: 70ucode]
#1436424
06/09/13 01:09 PM
06/09/13 01:09 PM
cudabin
Sounds like a great Street car engine!!!
What RPM was peak TQ at? can you post your dyno sheets?
Cheers,
Arnie
[Re: 70ucode]
#1436426
06/10/13 01:58 AM
06/10/13 01:58 AM
Posts: 5,163 CT
GTX MATT
CT
Hey John, I don't recognize your car from your avatar so I dont think I've seen it before. Should run strong for sure. I'm from Danbury so we're pretty close. I go to the Bills Drive in cruise on route 111 in Monroe on Saturday nights, its a small cruise but we get a lot of MoPars there. If you get a chance to pop over come check it out. We usually even have a Hemi Superbird there.
