Trans crossmember has blue paint from factory? #1436137
05/14/13 09:07 AM
05/14/13 09:07 AM
eastern, pa.
cudabitten Offline OP
eastern, pa.
I'm guessing the transmission crossmember was painted semi-gloss black. Mine has blue paint on it from the factory. I'm wondering why?
Re: Trans crossmember has blue paint from factory? [Re: cudabitten] #1436138
05/14/13 09:48 AM
05/14/13 09:48 AM
SE Pa.
LimeliteAero Offline
SE Pa.
how much history do you have with the car?
40 years is a long time for people to do odd things.
Re: Trans crossmember has blue paint from factory? [Re: LimeliteAero] #1436139
05/15/13 11:55 AM
05/15/13 11:55 AM
eastern, pa.
eastern, pa.
This is an original untouched 74 Barracuda.The paint looks a lot like the markings I found on the differential near the top. I'm thinking the blue paint is inspection marks. I found many of these on this project so far.
Re: Trans crossmember has blue paint from factory? [Re: cudabitten] #1436140
05/15/13 02:02 PM
05/15/13 02:02 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
If that is the case and in consideration of the location, it would be inspection marks verifying torque up of cross member to frame bolts. Underneath that blue paint is either black paint or bare metal depending on how the cross member support was finished back in the day.
Re: Trans crossmember has blue paint from factory? [Re: 70mopes] #1436141
05/16/13 03:18 AM
05/16/13 03:18 AM
the Netherlands
Mr4Speed Offline
Mr4Speed  Offline
the Netherlands
Chrysler had different vendors for some parts, if i am correct;
both my 1963 Savoy and 1963 Fury had light grey transmission crossmembers and k-members.
