Re: '71 Plymouth heater a/c water control valve
[Re: VITC_GTX]
#1436113
05/14/13 02:33 PM
05/14/13 02:33 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: RSNOMO]
#1436114
05/14/13 05:06 PM
05/14/13 05:06 PM
Posts: 2,592 None
71rm23
None
Thats the one needed, posted above then. Is there a couple of holes on the passenger side of the inner wheel well?
[Re: VITC_GTX]
#1436116
05/14/13 11:35 PM
05/14/13 11:35 PM
Posts: 553 DE
Ply72rr
DE
[Re: VITC_GTX]
#1436117
05/14/13 11:35 PM
05/14/13 11:35 PM
Posts: 2,592 None
71rm23
None
I do have holes on the inner wheel well but I'm not sure if the bracket on the valve has the same bolt pattern.
It appears you should have the valve pictured above. I have holes in the inner fender like yours but not sure of the deminsions. I think the hole in the upper left is for the fuel line. You can get the whole thing (valve and brackets) from several sources, just shop around for the best price. Also, you'll need the vacuum can that sits under the battery tray. There's a small line that goes from the can and connects to the little nipple in the top of the valve in the pictured above. The other kind is spliced into the heater hose lines and is not mounted to the fender well and has a cable to it from the inside. A manual is good to have, it shows it. Hope this helps
[Re: 71rm23]
#1436118
05/14/13 11:43 PM
05/14/13 11:43 PM
Posts: 4,929 Tri-Cities, Washington
VITC_GTX
The pictures, links and this description does help very much, thanks all.
I assumed the vacuum line on the valve came from the heater switch to open and close it. How does the vacuum from the can under the battery tray open/close the valve?
Unfortunately I only have a '69 Plymouth service manual.
[Re: 71rm23]
#1436120
05/16/13 03:19 PM
05/16/13 03:19 PM
VITC_GTX
It runs off of vacuum from the booster, and carb if memory serves me. Best thing to suggest is get the SM and its free
Thanks.
I haven't been able to find a '71 Plymouth SM that I can download.
