Motor Mount Question #1435996
05/13/13 08:34 PM
05/13/13 08:34 PM
Albuquerque, New Mexico
66coronet500 Offline OP
Will a 440 drop in place of a poly 318 in a 1966 Coronet with normal 440 motor mounts or do I need the Schumacher conversion kit?
Re: Motor Mount Question [Re: 66coronet500] #1435997
05/13/13 10:59 PM
05/13/13 10:59 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
All you need is the big block steel brackets that bolt to the engine block, the rubber mount is the same.
