removing main caps #1435022
05/12/13 11:44 AM
05/12/13 11:44 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
is there a correct way to do it? i,m tryin to be a little more refined in my assembly practices.i know how to shadetree it, BFH.
Re: removing main caps [Re: bonefish] #1435023
05/12/13 11:50 AM
05/12/13 11:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
bolts or studs out and rock them back and forth , turn the crank so the counterweight is out of the way . # 3 is the hardest , sometimes you can grab he center with visegrips to help wiggle it.
I can't even see how you could get a hammer in there and have it be helpful ?
I've always wondered if it's safe to drill and tap a cast iron main cap so one could use a slide hammer like you see alum caps ?
Re: removing main caps [Re: JohnRR] #1435024
05/12/13 11:55 AM
05/12/13 11:55 AM
IN
ahy Offline
ahy  Offline
IN
On the drilling and tapping... firing pressure puts the bottom surface of the cap in tension. Any disturbance, gap, scratch ect. can create a stress riser and start a crack. Not a good idea to drill a cap that wasn't designed for it.
Re: removing main caps [Re: ahy] #1435025
05/12/13 12:58 PM
05/12/13 12:58 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I use the old bolts as handles to rock #3 out. Even on a studded block I take the studs out before pulling the caps - since they're not supposed to be in there tight anyways (the studs - not the caps!). Rubber mallet - NEVER a hammer.
Re: removing main caps [Re: Stanton] #1435026
05/12/13 02:08 PM
05/12/13 02:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I used to use the palm of my hand to knock them loose.
Don't be the exception.
Re: removing main caps [Re: Supercuda] #1435027
05/12/13 02:39 PM
05/12/13 02:39 PM
Bismarck, ND USA
cageman Offline
cageman  Offline
Bismarck, ND USA
I have an engine with pro gram main caps, they have a notch in the sides to pry up with, sure is nice.
Re: removing main caps [Re: cageman] #1435028
05/12/13 03:49 PM
05/12/13 03:49 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
It sure is a PITA with studded mains
