Re: 4.500 crank question....bryant wingard[sp]???
[Re: imfixinmopars426]
#1434951
05/12/13 08:54 AM
05/12/13 08:54 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
They most likley have 8 bolts for the flex plate also. I used a bryant 4.5 stroke crank with the cracks for many years untill a blower hub failure messes up the snout
[Re: Dodgem]
#1434953
05/12/13 10:42 AM
05/12/13 10:42 AM
Lots of people say no,no on these cranks especially fuel cranks.
#1434955
05/14/13 08:17 AM
05/14/13 08:17 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
It may be possible to clean up the cracks with an offset grind to 4.650? That would be a 2.200 chev journal, and will fit in the stock block for a very large stroker. I mentioned in other posts that center counter weighted cranks are more forgiving for stock blocks, putting less stress on the blocks because the center weights distribute the loads more evenly. I ran a welded stroker for quite some time years ago at 650 hp in a stock block, 4.5 stroke with some serious cracks in it before it finally let go. Do you have info on what machine work it will take to make it usable?
