Re: Outside lighting for RACE CAR trailer
[Re: pittsburghracer]
#1434837
05/12/13 11:05 AM
05/12/13 11:05 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Don't know if this helps as it seems kind high.. http://www.ebay.com/itm/RECESSED-LIGHT-B...b7e&vxp=mtr
I dont have the outside lighting on my trailer and I dont know if I would put them on(JMO) but I do have 2 of the lights shown in the link and a double on a stand... seems like the mounted lights just dont get the light where you need them... again JMO... also I have ran into the light buckets inside the trailer on my buddies trailer... but I guess you get use to ducking your head after a few hits
[Re: J_BODY]
#1434843
05/12/13 06:13 PM
05/12/13 06:13 PM
MR_P_BODY
My electrician buddy gave me a pair of these to play around with. Was going to put them up in the yard, but I was also thinking they might work really well on the trailer. I too would fore go the buckets, and just hang them on a bracket when I got to the track. Easier to direct the lighting.
I sorta like these... who makes them and where do you get them... I like the idea of just hanging them on a bracket... plus they would be moveable so that would help
[Re: J_BODY]
#1434845
05/12/13 06:31 PM
05/12/13 06:31 PM
MR_P_BODY
the pict I posted are LED lighting. He's a vendor for these and I'm honestly not sure of the cost. I'm also curious to the power consumption. Hoping to be able to run them off the inverter/batt pack when generator use isn't required. Neat to have it plugged in for 10+ minutes and pick them up by hand because they are not scalding hot!
Well being LED I would think the power draw would be very low so if your inverter was big enough that it shouldnt be a issue.... J... if you can find out a price that would be cool
[Re: J_BODY]
#1434846
05/12/13 06:39 PM
05/12/13 06:39 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
J body that should work no problem as long as your inverter has a higher watt rating then your load.
Would guess your inverter is 300+ watts and your fixtures are like 30watts each. New LED flood lighting stuff is great.
"Just a Bracket car dressed up like a streetcar"
