hemi suspension brake help #1434787
05/11/13 08:11 PM
05/11/13 08:11 PM
PA
Y
yellowfin Offline OP
Y
PA
I'm at the point where the front drum brakes are getting redone on my 68 GTX, and found that someone had been in there before on the pass side and had replaced the OEM manual adjust (hemi/cop car)setup with an aftermarket conversion kit that automatically takes up the slack as the pads wear. I tried to procure a brake hardware kit from some local jobbers (autozone, napa, advance auto etc) for the required pieces, but its a no-go, they don't even have a listing for any supplier that has it available. I know, I know, the adjusting feature is nice, no one would ever see it, and I wouldn't have to get under the car to keep things snug. But the thing is so dang original I just hate to modify if I don't really have to. Even all the wheel cylinders were the factory pieces (except that one) and I went the expense to have them resleeved in brass just to retain the factory setup. I really only need the one bottom spring that stretches between the two shoes and over the adjusting mechanism to keep it from turning with vibration. The other springs interchange with the OEM ones. Any other sources out there that would carry this part?
Re: hemi suspension brake help [Re: yellowfin] #1434788
05/11/13 09:53 PM
05/11/13 09:53 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
That's a good question.. I'm not sure if I switched my '68 over to self-adjusters. I was going too but it was so long ago that I probably don't have the hardware anymore.
Good luck
Re: hemi suspension brake help [Re: yellowfin] #1434789
05/13/13 04:19 AM
05/13/13 04:19 AM
AZ.
696pack Offline
696pack  Offline
AZ.
I don't think it IS hardware but rather the lack there of. I think you just remove the adjusting pawl that tightens them up when you back the car up.
Re: hemi suspension brake help [Re: 696pack] #1434790
05/13/13 10:36 AM
05/13/13 10:36 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I think D is right on this , there is an adjust wheel still , just no auto adjuster linkage. But 68 may have been more archaic setup?
Re: hemi suspension brake help [Re: yellowfin] #1434791
05/15/13 10:51 AM
05/15/13 10:51 AM
n/w, PA
demonH1B Offline
demonH1B  Offline
n/w, PA
These springs are very hard to find. I bought some a few years ago
from Brads NOS, but no longer on inventory. The OEM numbers
are 2944844-spring and 2265201-adjuster.
