Re: E Body seats.
[Re: 4406RAY]
#1434532
05/11/13 02:24 PM
05/11/13 02:24 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
70 and early 71 had the springs attached to the seat frames. Sometime in 71 up to 74, the springs are built into the foam. So check and see which style you have. As far as fit, do you plan to reuse the foam and are the covers the same style as the old ones?
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: E Body seats.
[Re: 4406RAY]
#1434534
05/11/13 11:24 PM
05/11/13 11:24 PM
Silver70
Rust Belt, SW PA
I believe the foam would be different if they are the style I'm thinking of. But you need to check for the spring style in the frames/foam.
