redraptor 3.0 #1434392
05/11/13 10:21 AM
05/11/13 10:21 AM
Greenville, PA
redraptor Offline OP
Greenville, PA
After a LONG winter I got some time to improve/finish some stuff on the raptor I didn't get to last year. The PVC cooling pipe thing didn't work out so well. Another member had mentioned he used trampoline pipe so I tried it and it worked out well. The PVC made an excellent template and no leaks so far.
Scrapped 2 radiators and got a new one.
Went with the quad lamp set up but plugged off the lower buckets.(useless to have lites that low) Added clearence lites I scavaged from another truck. Really wanted to paint the whole truck this year but only did the fenders I replaced.
I also picked up another pair of boggers for the rear suitable for trailriding. Had to retire the old paddle wheels.
Re: redraptor 3.0 [Re: redraptor] #1434393
05/11/13 11:32 AM
05/11/13 11:32 AM
scratchnfotraction Offline
SSWWWEEETTTT!!!!!
what problems did the pvc pipe have?
I used elect. EMT pipe before same way. it had pre-bent sweeping 90* that mad things nice.
how much did it add to the the cooling system capacity?
Re: redraptor 3.0 [Re: scratchnfotraction] #1434394
05/11/13 11:51 AM
05/11/13 11:51 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I wanna make a pass with it !!!
I am truckless..
Re: redraptor 3.0 [Re: 340SHORTY] #1434395
05/11/13 08:03 PM
05/11/13 08:03 PM
plymouth, NH
E
ejtmopar Offline
ejtmopar  Offline
E
plymouth, NH
me too!!
Re: redraptor 3.0 [Re: scratchnfotraction] #1434396
05/12/13 08:41 AM
05/12/13 08:41 AM
Greenville, PA
Greenville, PA
SSWWWEEETTTT!!!!!
Thanks.
The problem with PVC is you have to keep the temp below 200 deg. or it will start to sag. The old radiator I had wasn't up to the task even with a 160 stat. Secondly, there wasn't anyway to barb the ends to keep the hoses on. Double clamping worked until you got overtemp. I do recommend using PVC to mock up your routing.
I looked seriously at some EMT. The bends were too large for anything I did. My other choice was Summit exhaust tubing with some pre-bent turns.
Not sure about capacity. Maybe a gallon.
Re: redraptor 3.0 [Re: 340SHORTY] #1434397
05/12/13 08:47 AM
05/12/13 08:47 AM
Greenville, PA
Greenville, PA
Sure, Larry! Anytime you find yourself in the area.
Re: redraptor 3.0 [Re: redraptor] #1434398
05/12/13 09:42 PM
05/12/13 09:42 PM
Pennsylvania
scannman70 Offline
scannman70  Offline
Pennsylvania
looks great...I need to find me a set of boggers, for my 1970 Jeep truck build...
Re: redraptor 3.0 [Re: scannman70] #1434399
05/13/13 08:27 PM
05/13/13 08:27 PM
Greenville, PA
Greenville, PA
Thanks! There's alot of stuff on Pennswoods in your area but I can't afford the time to go. Bought both pairs on craigslist and had to look everyday for months for something decent at a decent price.
