Re: Reverse Rotation 318
[Re: oldman]
#1434266
05/10/13 10:37 PM
05/10/13 10:37 PM
RapidRobert
Saw one in an inboard speedboat but never got into the innards. I'd assume with the reverse rotation changing the thrust sides that the piston offset (if present) would want to be reversed to keep it functioning
[Re: RapidRobert]
#1434267
05/10/13 10:46 PM
05/10/13 10:46 PM
Posts: 1,395 LAKE TEXOMA
oldman
LAKE TEXOMA
Yes thats what I'm working on a motor for a 1970 century Boat
[Re: oldman]
#1434268
05/10/13 10:48 PM
05/10/13 10:48 PM
RapidRobert
iirc the firing order was 2=1=8=4=3=6=5=7 & I'm not even sure about that. It was a strange duck
[Re: RapidRobert]
#1434269
05/10/13 10:50 PM
05/10/13 10:50 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
also polish the crank in the opposite direction
[Re: Cab_Burge]
#1434271
05/11/13 08:02 AM
05/11/13 08:02 AM
Posts: 1,444 NEW JERSEY
dynamite
NEW JERSEY
Reverse the pistons,notch to the back and leave the rods were they were..polish off the rear seal groves ..use the rope type seal..and the firing order is 1=2=7=5-6-3-4=8..
[Re: jjl]
#1434275
05/13/13 06:47 AM
05/13/13 06:47 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
All automotive are LH, left hand. Many marine are RH, right hand, even in single engine boats. The RH prop torque thrust in a single engine small boat helps trim it back to level when one person is aboard (right side heavy).
Are you building a new motor off an automotive core? If so, -reverse the pistons on the rods, not the rods on the crank -polish out LH rear main knurling and use a neoprene seal not rope, if you have RH knurling leave it and use a rope seal -use a reverse cam core, SB may be available new, BB isn't, besides location of lobes, the gear is cut backwards -use a reverse dist/oil pump drive gear, this allows std oil pump -use a marine thrust block between block and dist, the LH drive gear walks down against the block bushing, the RH drive gear tries to walk up so a thrust block is needed -marine dist is special with spark arresting features, it does rotate the same direction as LH, just the wire order is reversed from 1-8-4-3-6-5-7-2 to 1-2-7-5-6-3-4-8 -marine carburater, alternator and starter are special with spark arresting features, carb uses spark arrester instead of an air cleaner -water pump depends if it is raw water or heat exchanger cooled -and of course the exhaust manifolds are water cooled
What model Century? What trans, Borg Warner or Paragon? Any pics?
