Re: Steering wheel pulls out about 1/2" Adjustment?
[Re: buildanother]
#1434039
05/10/13 09:39 PM
05/10/13 09:39 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
67 doesn't have a collapsable column.. 1/2" is the movement allowed but the coupler... Does the outer column move or just the shaft/steering wheel?
If it's just the shaft/steering wheel then as mentioned about probably a snap ring has failed/is missing... I just did a column out of a 71 Cuda that was missing both of those snap rings & a few other parts.. Lots of people have had their hands in these cars..
[Re: 1_WILD_RT]
#1434043
05/11/13 11:09 AM
05/11/13 11:09 AM
67 doesn't have a collapsible column..
That is not correct. Collapsible steering columns were introduced in the 1967 model year.
[Re: rapom]
#1434046
05/11/13 09:19 PM
05/11/13 09:19 PM
I thought so but I'm kind of sure my problem is the snap ring. I'll check that 1st. then look at the shaft.
If the shear pin in the collapsible column were sheared off, you would be able to pull the lower end of the shaft in or out, but not the steering wheel unless something is missing/loose at the steering wheel end as suggested above.
#1434047
05/11/13 09:50 PM
05/11/13 09:50 PM
moparpollack
Lil Herman
Lil Herman
85086
To fix this you will need to pull your steering wheel. Under the steering wheel are two nuts that need to be tightened. If you are not carefully the nuts will just tighten up, but if not you will need to turn the bolts so they lock into their retainer. Easier to find out pulling the car into the garage than driving down the road.
[Re: rapom]
#1434049
05/12/13 06:08 AM
05/12/13 06:08 AM
Posts: 1,032 Ohio
dobie
Ohio
I had and fought much of the same issue last fall. Two things were wrong...The first issue I had was the whole dang steering wheel coming nearly off while driving. Upon examination, the coupler where the steering shaft meets the box had come apart, allowing the whole shaft to pull through. I replaced the coupler thing, and sure enough it did it again. Looking further into it, the large white bearing had broken onside the column. That caused the shaft to be pulled out of the coupler, especially on hard acceleration. Once I replaced the bearing and the coupler parts again it's been fine ever since.
1968 Plymouth Road Runner
383 4 speed
