Wilwood disc brakes #1433991
05/10/13 01:30 PM
05/10/13 01:30 PM
visalia,ca,USA
bluebird69 Offline OP
visalia,ca,USA
I have a 68 dart with wilwood disc brakes on all four corners and I'm not sure what master cylinder will work/ to use. Any info is appreciated
TAKES A MOPAR TO CATCH A MOPAR
Re: Wilwood disc brakes [Re: bluebird69] #1433992
05/10/13 05:22 PM
05/10/13 05:22 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Call wilwood?
need to know a LOT more about the system before answering a question like that! what are the piston sizes in all the calipers?
power brakes or manual brakes?
**Photobucket sucks**
Re: Wilwood disc brakes [Re: bluebird69] #1433993
05/10/13 09:16 PM
05/10/13 09:16 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Click me!
Re: Wilwood disc brakes [Re: Lefty] #1433994
05/11/13 12:12 AM
05/11/13 12:12 AM
ar.
bobs69 Offline
bobs69  Offline
ar.
I had wilwood on all four courners of my 69 charger used the stock master cylinder worked fine
Re: Wilwood disc brakes [Re: bluebird69] #1433995
05/11/13 12:19 AM
05/11/13 12:19 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Go here
http://www.markwilliams.com/braketech.aspx
My 64 Belvedere with Wilwoods required a 1 1/8" with the stock pedal ratio. Works great. I had tested a 1 1/32" because it was what I had, not good.
Doug
