Rear K car springs?
#1433806
05/09/13 11:40 PM
05/09/13 11:40 PM
Posts: 457 Hightstown, NJ
njdevil2
Hightstown, NJ
OK this is gonna sound really crazy but.... I just purchased a 1986 Reliant 2.5 SE Coupe with 36K miles (yes original and verified). The rear is sagging just enough to make me crazy. Here's the question...I have no aspirations that this thing is gonna be a corner carver, but I'd like to to: A) Be even or a wee bit higher in the aft end. B) Handle a wee bit better than normal. I am considering a pair of K car Wagon springs over the stockers.... Comments/ideas/suggestions? At some point I'll be putting 195-70R14's on it as my brother in law has wheels from a Shadow. And that profile is an upgrade in 87 K cars I believe.
1970 road runner Convertible 1 of 179
Re: Rear K car springs?
[Re: njdevil2]
#1433807
05/10/13 12:37 AM
05/10/13 12:37 AM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
New springs and new gas shocks and you will be suprised how it sits.We had older Cavilars and Celebrites come in with worn shocks.Just changing them to new gas raised them.Rocky
Chrysler Firepower
[Re: superwrench]
#1433810
05/10/13 10:47 AM
05/10/13 10:47 AM
njdevil2
Hightstown, NJ
Doing a quick check on an '87 Shelby Turbo Z, the shocks all cross reference, so the shock idea I'm considering first. The coils don't cross reference on face value, but I also found variable coils, not too sure about them. I can get a spring set for $60 + state tax and the Monroe shocks $70 a pair.
[Re: 71birdJ68]
#1433812
05/10/13 11:21 AM
05/10/13 11:21 AM
njdevil2
Hightstown, NJ
No way....I'll check that out.... I was thinking about turbo, then small block.....geez, I'm gonna get in trouble....
[Re: 71birdJ68]
#1433813
05/10/13 01:36 PM
05/10/13 01:36 PM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
Wondering if Shelby Charger or GLH stuff will fit? Those cars handled very well. Just a thought.
L body chassis and K-car chassis are two completely different animals. There both fwd and 2.2 is about the only thing that is the same between them.
[Re: superwrench]
#1433814
05/10/13 02:47 PM
05/10/13 02:47 PM
therocks
Niles , Ohio
Load leveler springs wont really raise it.They are made so when you add weight they increase the pressure so the car dosent sag as much.I installed quite a few at the shop.Try a set of good gas shock.People say shocks dont lift the car.Ive seen it quite a few times where they did.For better handling you will need them anyway.Rocky
Chrysler Firepower
[Re: therocks]
#1433815
05/10/13 03:53 PM
05/10/13 03:53 PM
njdevil2
Hightstown, NJ
Fast K car...OMG!!! That was ridiculous.. http://www.youtube.com/watch?v=2yT6tPsMfjII think I'm gonna try the shocks first. I did cross reference the shocks and they are the same from Z car to K car...same part number. I kinda figured the L body was different. The springs are just as easy as the shocks. If it were in the budget, I'd do both the same time.
[Re: njdevil2]
#1433816
05/10/13 05:36 PM
05/10/13 05:36 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Thanks, wait till it comes back out.
The Daytona shocks and springs will interchange, the Daytona springs will cause the car to sit lower though.
[Re: gdonovan]
#1433817
05/10/13 07:53 PM
05/10/13 07:53 PM
njdevil2
Hightstown, NJ
Yeah, I need it to sit higher... What's in the K? Loved that video..
[Re: njdevil2]
#1433818
05/10/13 09:16 PM
05/10/13 09:16 PM
gdonovan
Oakdale CT
2.5 SOHC with hybrid T3/T4 turbo running 35 psi of boost on 88-89 SMEC electronics with 85 pph injectors, 3 bar map of course.
Look up springs for a dodge spirit or plymouth caravelle, both are larger bodys and the springs should interchange.
[Re: njdevil2]
#1433819
05/11/13 07:33 AM
05/11/13 07:33 AM
gdonovan
Oakdale CT
For handling- Get a set of 15 x 6.5 "crab rims" and install 225/50-15's, (avoid the 16" shelby wheels, rubber is too tall and rim too narrow) lay hands on a turbo z or Daytona shelby (85-88) sway bar (1 1/8") and you will find the car will handle very sharp. 89-91 is a different k-frame so the sway bar will not fit.
I have noted a strut brace does work well with these cars, if you are handy with a welder you can make your own.
[Re: gdonovan]
#1433820
05/11/13 09:39 AM
05/11/13 09:39 AM
njdevil2
Hightstown, NJ
I think I'm going to go with the Moog 8261 (I think) rear springs from the wagon. Next upgrade will be the KYB's from what I've looked at. What do the crab wheels look like? I can't weld to save my a$$.... but I know someone. If not I may be able to construct one, I've got measuring tools and a grinder...
[Re: njdevil2]
#1433821
05/11/13 10:31 AM
05/11/13 10:31 AM
gdonovan
Oakdale CT
What do the pumper wheels look like?
Sorry I didn't have enough coffee- You want the crab wheels, not the pumpers. I'll post a picture of both. Here is a picture of my Daytona with "crab" rims.
Note- They also made a 6 inch wide version for Shadows, not as good as the Daytona's 6.5"
[Re: gdonovan]
#1433823
05/11/13 10:41 AM
05/11/13 10:41 AM
njdevil2
Hightstown, NJ
AH!! I see. I may run to the local junk yard, there were more than a few shadow/sundances there but I didn't notice the wheel. I get in free, so it's no big deal.
[Re: njdevil2]
#1433824
05/14/13 12:01 PM
05/14/13 12:01 PM
njdevil2
Hightstown, NJ
gd - I FOUND your website....that's awesome. I'd love to get into the 13's with this and have it handle better. I'll be picking up my springs this afternoon. I'm lusting for a T2, but that'll have to wait for a bit. My plan of attack right now is: Springs Sway Bar Wheels and Tires This budget thing sucks, but I gotta do what I can afford. If the employment fairy blesses me with a better paying job, then things will accelerate. Literally, ha!
[Re: njdevil2]
#1433825
05/19/13 01:02 AM
05/19/13 01:02 AM
njdevil2
Hightstown, NJ
It sucks being on a tight budget, but someone locally is selling his pizza rims with good 195-65/15 BFG Touring tires. I realize they are 15X6, but can I get away with using them? They can be had for $100, off his Shadow. With these rims, what size tire am I limited to? Thanks again for all the help!
