1997 dodge ram water pump question #1433369
05/08/13 11:48 PM
05/08/13 11:48 PM
southern illinois
Y
yellowscamp Offline OP
Y
southern illinois
Do they make a high volume water pump for a 1997 dodge ram pickup. 360 4wd. Water pump went out today and have to get a new one. Was wanting to know because I might be pulling a camper with it later on.
Re: 1997 dodge ram water pump question [Re: yellowscamp] #1433370
05/09/13 12:01 AM
05/09/13 12:01 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Nope. They are all the same. Only difference is if the pulley is pressed-on or bolted-on.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 1997 dodge ram water pump question [Re: 71yelladustr] #1433371
05/09/13 12:06 AM
05/09/13 12:06 AM
southern illinois
Y
Y
southern illinois
thanks
Re: 1997 dodge ram water pump question [Re: yellowscamp] #1433372
05/10/13 08:57 PM
05/10/13 08:57 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
You'll probably need an air chisel to loosen the large nut that holds the fan clutch on the water pump. It's a learning experience first time in.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
