Water Pump for 340--6 vane or 8 ? #1432340
05/08/13 04:10 PM
05/08/13 04:10 PM
Marion, SC USA
69RR383 Offline OP
69RR383  Offline OP
Marion, SC USA
My 340 has an 8 vane water pump-6 vane water pumps for the 340 are readily available- 8 vanes are not & have to be sent off for rebuild-is the 8 vane needed for an essentially stock 71 Demon-340 or will the 6 vane be adequate for a street car with an occasional strip pass ? TIA
Re: Water Pump for 340--6 vane or 8 ? [Re: 69RR383] #1432341
05/08/13 04:59 PM
05/08/13 04:59 PM
An 8 vane will flow more but a 6 vane will work & I'd weld a round anticav plate to the vanes, simple to do & vastly increases it's effectiveness
Re: Water Pump for 340--6 vane or 8 ? [Re: 69RR383] #1432342
05/08/13 04:59 PM
05/08/13 04:59 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..the size of the pulley will determine the pump speed.
a small pulley will use the 8 and a large pulley will use the six
..or have i got that backwards?..the slow speed would use the 8.
Re: Water Pump for 340--6 vane or 8 ? [Re: can.al] #1432343
05/08/13 05:01 PM
05/08/13 05:01 PM
Andrewh Offline
Andrewh  Offline
8 is slower, non-ac car
6 vane is faster a/c car
they felt the 8 vane would cavitate more.
Re: Water Pump for 340--6 vane or 8 ? [Re: Andrewh] #1432344
05/08/13 05:07 PM
05/08/13 05:07 PM
Marion, SC USA
69RR383 Offline OP
69RR383  Offline OP
Marion, SC USA
Thanks for the replies--guess I'll have the 8 vane rebuilt since it is a non-ac car
Re: Water Pump for 340--6 vane or 8 ? [Re: 69RR383] #1432345
05/08/13 05:11 PM
05/08/13 05:11 PM
scratchnfotraction Offline
8 vanes = non A/C pullys-turns slower and pumps x amount of water at idle.
6 vanes = A/C pullys- turns faster and pumps same x amount of water at idle.
at higher RPM with the 8 vanes/smaller A/C pullys there is a chance it will cavitate.
the t-stat by-pass hose should not be blocked, it keeps the vanes from cavitating while t-stat is closed. you can block it if you run a restrictor plate instead of the t-stat.
welding a anti-cavitation plate onto the vanes helps flow and prevents cavatation.
is this the early cast iron WP?
I get a new, heavy duty cooling 5/8 shaft/large bearing 8 vane pumps at napa for 65$ (neck has ribs not gun barrels)
with all that said I have mixed match vane count and pully size many time and never had any trouble as long as the rest of cooling system was up to specs.
put a 6 vane on and run it.
Re: Water Pump for 340--6 vane or 8 ? [Re: can.al] #1432346
05/08/13 05:19 PM
05/08/13 05:19 PM
A/C used the smaller pulley/6 vane so the fan would turn faster for more airflow at idle for additional cooling yet the 6 vane would keep it from cavitating at higher RPM's with the higher vane speed from the smaller pulley since the 6 vane flowed less coolant. For the whole scoup from the Master go to www.moparchat.com then scroll down to & click on "circle track chat" then read thru Sanborns' cooling mods that are in a sticky at the top of the page
Re: Water Pump for 340--6 vane or 8 ? [Re: 69RR383] #1432347
05/08/13 05:26 PM
05/08/13 05:26 PM
P
Paul_Fancsali Offline
P
Strongly urge the use of a 8 blade pump My 340 nalways ran hotter with a 6 blade pump I use a 6 blade on a 360 but I have a cavitation plate on it
Re: Water Pump for 340--6 vane or 8 ? [Re: Paul_Fancsali] #1432348
05/08/13 06:10 PM
05/08/13 06:10 PM
Marion, SC USA
69RR383 Offline OP
69RR383  Offline OP
Marion, SC USA
Thanks for all the input guys- I've learned alot about water pumps- I've located a new heavy duty 8 vane at NAPA and will go with that--thanks again
