on 4 corner idle setting #1431822
05/07/13 03:50 PM
05/07/13 03:50 PM
mississippi
bentwheel43 Offline OP
mississippi
I had 2 idle setting on a 850,now I have 4 corner idleing.I always set the 2 idlers 2 rounds out,but now 2 rounds seem to rich on 4 corner idle (burns my eyes rich).What you guys set a 4 corner 850 at?
Section 8 Racing We are nuts about racing.
Re: on 4 corner idle setting [Re: bentwheel43] #1431823
05/07/13 04:00 PM
05/07/13 04:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Slowly turn in each one till the idle starts to drop
then back it out a 1/8 to 1/4 turn... do this on each one
and turn your idle screw down as needed... this may
need 2 or 3 times around to get it right
Re: on 4 corner idle setting [Re: MR_P_BODY] #1431824
05/07/13 04:41 PM
05/07/13 04:41 PM
mississippi
mississippi
Re: on 4 corner idle setting [Re: bentwheel43] #1431825
05/08/13 01:48 AM
05/08/13 01:48 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I would bet 3/4 of a turn out would be a close starting point. If you have a vacuum gauge tune to the highest vacuum reading then equalize all 4 to the same...then re-adjust the idle screw to the desired setting.
Re: on 4 corner idle setting [Re: Forest] #1431826
05/08/13 10:30 AM
05/08/13 10:30 AM
mississippi
mississippi
Thats what I ended up with 3/4 turn out.1 full turn was still a little much.Iam within an 1/8 turn are close now.That thing ran out of gas
