The tubing is responsible for keeping the reset knob at its correct location on the dash. Mine is completely destroyed and it allows the inner cable and knob to push right out of the dash.
my plan would be to slid some plastic tubing length wise and wrap it over the steel wire. Then tape the slit [Edited by Moparts - Family Friendly Site - Keep it clean], and epoxy the ends to the metal fittings. I just need to know the length of plastic tubing between the fittings so i can make sure the knob is going to be at its proper position.
And ya, i went ahead and ordered that quartz clock with the instruction dvd off of ebay.
