Re: Help! - sway bar bushing install
[Re: yellowfin]
#1431670
05/07/13 11:02 AM
05/07/13 11:02 AM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Some people go to the trouble of removing the brackets and then rewelding them with the bushing in place. I have always just lubed them up with WD -40 start them first at the top of the triangle part of the bushing and work my way to the bottom on each side. I use stong language, channel locks, large plyers, and large vise grips to get them to go in. It is rough but it can be done.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#1431671
05/07/13 01:14 PM
05/07/13 01:14 PM
I agree. I did the ones on my 69 Charger and fought with them tooth and nail using some colorful language even having a screw driver slip off and gash my palm of my hand pretty good. Like Mike said, try some lube, either WD-40 or some other type of grease with the channel locks. It won't be easy by a long shot, but they usually will go in. I've also heard that the way that was done originally was to slip the bushing on and then weld the strap in place.
[Re: ]
#1431672
05/07/13 03:20 PM
05/07/13 03:20 PM
Posts: 299 Hinckley, Ohio
KWF340
Hinckley, Ohio
I ran into the same problem on my Dart. I eventually was able to get one side done, but not the other. Ended up cutting the bracket. Bushing
1968 Charger R/T, 440 Auto, GG1; 1969 Super Bee, 383, 4-speed, T5; 1969.5 Road Runner, 440-6, 4-speed, 96; 1970 Duster 340, 4-speed, EV2; 1970 Charger R/T SE, 440 (496), Auto, EB3; 1970 Dart Swinger 340 (416), 4-speed, EV2; 1970 Corvette coupe, LS5, 4-speed, Daytona yellow; 2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
[Re: can.al]
#1431674
05/07/13 08:31 PM
05/07/13 08:31 PM
Posts: 532 Charlotte, NC
Kowal
Charlotte, NC
I just did a set. Did not have to cut the bracket.
Grease the heck out of it. I used channel locks and a Phillips screw driver and just worked it a little bit at a time, then there is a point where it pops in. I agree with the earlier comment, do it by the narrower diameter of the bar.
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: Kowal]
#1431675
05/07/13 08:34 PM
05/07/13 08:34 PM
Kowal
Charlotte, NC
[Re: FJR doc]
#1431678
05/09/13 09:56 AM
05/09/13 09:56 AM
Kowal
Charlotte, NC
I'll be installing new bushings in my sway bar in the near future. I thought that I might be able to use my shop press to help get the bushing pushed in. Am I delusional?
No working room, the bar has to be in the rubber bushing before it can be squeezed in to the bracket.
Again, it can be done, I did it with a couple of hand tools and just some patience. Really.
[Re: yellowfin]
#1431683
05/11/13 07:46 PM
05/11/13 07:46 PM
Posts: 43 PA
yellowfin
PA
As an update, I tried to use different lube, stuffed the top of the bushing in first, then tried the bottom, then a side. No way it was going in there, even with two locking pliers, a screwdriver for leverage and a channelock. I ended up actually damaging the bushing on one of the sides (permanent deformation)during one particularly intense attempt. Not to mention what the bracket looks like after I sandblasted it, plated with zinc and then two coats of black por-15. Bottom line - the hole in the bushing is no longer concentric, so instead of possibly ruining the thing, I'm going to cut the bracket and see how that works. With a spray bottle of water handy, I think I can reduce the heat after running the weld bead enough to minimize any damage to the bushing. Wish me luck.
[Re: FJR doc]
#1431687
01/01/15 02:22 AM
01/01/15 02:22 AM
Does anyone repro that strap that is welded around the bushing? I know they tend to get beat up pretty good from curbs and such over the years.
