Re: gas percolating issues
[Re: mickm]
#1431272
05/06/13 03:31 PM
05/06/13 03:31 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I'm fighting this same problem with my Quadrajet. I have a nice Moroso phenolic spacer and I can still hear the fuel percolating after shutdown. I've seen people run flat sheetmetal heat shields that block some radiant heat from the intake, but I'm wondering if spraypainting the intake with header paint might make more of a difference. I'd rather not go the electric fuel pump route since that feels like a band-aid after the actual issue.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: Secret Chimp]
#1431273
05/06/13 04:14 PM
05/06/13 04:14 PM
Posts: 889 Oh
parksr5
Oh
Even with an electric pump, it is still an issue. I have an electric fuel pump and I have the same issue although, I'm sure the electric pump makes it a little easier to start over a mechanical pump.
[Re: parksr5]
#1431274
05/06/13 04:20 PM
05/06/13 04:20 PM
Secret Chimp
Eugene, Oregon
Are you using an iron or aluminum intake? I have an aluminum Edelbrock and it throws off a lot more heat than the old iron 2 barrel that came with the car.
[Re: mickm]
#1431278
05/06/13 04:59 PM
05/06/13 04:59 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
ok, just typed in "carburetor gasket heat" on summit's site, and have all kinds of options from edelbrock. just have to look them over and see what the thickness of these are. good starting point though.
Mick,
Had the same problem. I bought some composite gaskets from summit. Even the 1/4" help, however, the air cleaner does rub a bit in a couple of places on the airbox.
Do you have any non ethanol fuel available in your area? Ethanol tends to flash off pretty quickly. It doesn't help that the edelbrock/carter fuel bowls are small.
[Re: mickm]
#1431279
05/06/13 05:07 PM
05/06/13 05:07 PM
Secret Chimp
Eugene, Oregon
here we go, from the edelbrock site. the last 4 digit number is the edelbrock part number.
Square-Bore Heat Insulator Gasket - 0.320" thick 9265 Divided Square-Bore Heat Insulator Gasket - 0.320" thick 9266 Square-Bore Heat Insulator Gaskets for Edelbrock Dual-Quad Manifolds - 0.125" thick - 2 gaskets included 9267
IMO I would not go with just a gasket. I have a half inch phenolic spacer and still have problems. And I'm not exactly running a 11:1 engine in Florida or anything.
[Re: Secret Chimp]
#1431280
05/06/13 05:23 PM
05/06/13 05:23 PM
Posts: 4,179 California
mickm
California
the issue is linkage, hood clearance, etc... i'm going to try the gaskets from edelbrock first and go from there. if it isn't enough, i'll make a decision at that point.
[Re: mickm]
#1431281
05/06/13 06:38 PM
05/06/13 06:38 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Those gaskets are not made of any special material FWIW. They are just thicker.
I'm in the process of developing a gasket out of advanced materials to combat the heat transfer issues.
Stay tuned
[Re: roadhazard]
#1431282
05/06/13 07:25 PM
05/06/13 07:25 PM
mickm
California
Stay tuned
interesting. if you go to the webiste, the description is of a rubber compound or something like that.
PM me when you have something!
[Re: mickm]
#1431283
05/06/13 07:56 PM
05/06/13 07:56 PM
roadhazard
Akron, Ohio U.S.A.
Stay tuned
This would be a totally different material than our standard performance base gaskets.
I'll let the word out after I get some made and tested. Can't say when it will be as I have lots of irons in the fire
[Re: Secret Chimp]
#1431286
05/06/13 10:36 PM
05/06/13 10:36 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
You may think the electric fuel pump is a bandaid , and to a degree it is, but there isn't a wondergasket that will make this go away. The problem is the ethanol in the fuel, what the electric pump does is fill the fuel bowls so the car has fuel to start on, the only way to isolate the carbs is to get them away from the heat source, a 1/4" gasket isn't going to do that. You still have your carb sitting on the heat source and sitting under an air cleaner assembly that is slowing the escape of the heat.
[Re: Jjs72D]
#1431289
05/07/13 10:23 AM
05/07/13 10:23 AM
JohnRR
U.S.S.A.
As I understand it, the Road Runner is likely a factory appearing car and you prefer to keep it that way? I was thinking that some sort of return line may help. Something designed to keep fresh fuel in a loop instead of heated fuel just sitting in the fuel bowls. I'm not sure of how you'd do it though. Jeff
That will help when driving, I know of one member that has/had a fuel perk issue while running once everything got hot , but that's not going to do anything for most people problems ... gas boiling off after shutdown.
