Re: gen 2 hemi head cutting ?
[Re: domingo]
#1431086
05/06/13 11:31 AM
05/06/13 11:31 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
Id measure the diameter of you combustion chamber and do the math as if it was the thickness of a gasket....should get you pretty close. better to shave a bit less than a bit too much....cc them again and see if you have to shave em any more than that.
This is moparts , surely I can get someone else to do that and tell me the answer?
But good point on the head gasket thickness .
I looked in my 2002 vintage MP catolog and it says they are supposed to be 170cc just like original castings ... NOT ...
Why does this not surprise me.
[Re: JohnRR]
#1431087
05/06/13 11:37 AM
05/06/13 11:37 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Myself I would pour in your amount of liquid to see where thats at... then measure what you need to cut (of course this is with the head level)... no guessing
[Re: JohnRR]
#1431088
05/06/13 11:41 AM
05/06/13 11:41 AM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
the newer castings are 172 to 173 ccs new
[Re: domingo]
#1431091
05/06/13 12:33 PM
05/06/13 12:33 PM
JohnRR
Yes I found that out at 2am this morning
I'm trying to decide how much money to spend. I would like to bump the compression on the hemi to 10.5 , but I don't really have $2500 kicking around to do it via the stroker route ... As it is it's going to be 1500 to buy new semi custom pistons , bore and rebalance
[Re: dogdays]
#1431093
05/06/13 11:03 PM
05/06/13 11:03 PM
JohnRR
You are looking for 5cc, that'll be about 0.020".
I just did the math on a 4.25" bore, 5cc is 0.0215".
This is not exact but it'll get you closer..... R.
Thanks , I really wish I could cut the head that much , as it is the edge of the intake valve is close to the OD of the chamber ... which is close to 4.320 ...
The fix is a semi custom piston with a 92cc dome ... or the 4.375 stroke crank I put my name on ...
[Re: JohnRR]
#1431094
05/06/13 11:06 PM
05/06/13 11:06 PM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
The Mopar Hemi engine manual says remove .0041" for each cc. For each .010 removed cut .0085" off the intake face and .0116" from the front and rear rails of the block.
2011 Drag Pak Challenger
[Re: rickseeman]
#1431095
05/06/13 11:29 PM
05/06/13 11:29 PM
JohnRR
Thanks Rick . I have that engine book buried somewhere around here ...
[Re: JohnRR]
#1431096
05/07/13 04:55 AM
05/07/13 04:55 AM
domingo
EL Master
EL Master
Lima, Peru
Yes the intake valves are veryclose to the edge of the chamber, but you can still mill them. Take your intake valve out and see where the valve seats. All you need is that the valve is still sitting. The edge of the valves will protrude a bit past the flat surface of the head after you shave them.
Still I would advice to get a stroker crank or custom pistons to get you where you want compression wise....why shave the heads when its not needed? HEMI heads are expensive.
