leaf elimination on d100 truck #1430916
05/05/13 09:37 PM
05/05/13 09:37 PM
US
BBD150 Offline OP
BBD150  Offline OP
US
i want to eliminate the leaf springs on a short bed d100. i plan on doing a 4 link with coil overs to replace them. any suggestions on which 4 link i should be looking at. the rear end is a d60. i plan on racing it but it will mostly be driven on the street.
Re: leaf elimination on d100 truck [Re: BBD150] #1430917
05/05/13 09:42 PM
05/05/13 09:42 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
what kind of racing?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: leaf elimination on d100 truck [Re: amxautox] #1430918
05/05/13 10:13 PM
05/05/13 10:13 PM
US
BBD150 Offline OP
BBD150  Offline OP
US
drag
Re: leaf elimination on d100 truck [Re: BBD150] #1430919
05/05/13 10:17 PM
05/05/13 10:17 PM
amxautox Offline
amxautox  Offline
then it would be better to ask this in the drag race forum instead of the Handling Forum. it would be a little bit different set up.
Tom
author unknown
Re: leaf elimination on d100 truck [Re: amxautox] #1430920
05/06/13 02:21 AM
05/06/13 02:21 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
for a truck that will see limited drag action I would go with a ladder bar set up. Ladders bars are much easier to install plus set up is easier and theu are cheaper. You wont need the infinite adjustment of a 4 link setup. However if you see yourself getting more serious with drag racing then the 4 link might be a better option..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: leaf elimination on d100 truck [Re: HOTMOPR] #1430921
05/06/13 02:28 AM
05/06/13 02:28 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
The step ups on the frame won't allow for the stock bed floor if you do it right.
You could weld brackets to the stock rails maybe , but you want that stuff to be rock solid and you'd be surprised at how much they will twist.
There is a fellow from southern Mn. who posts here and I can't swear to his handle , but it is D-100 ish in nature.......he has a well done Hemi in his and has probably had every problem you will face.
Re: leaf elimination on d100 truck [Re: tubtar] #1430922
05/06/13 02:34 AM
05/06/13 02:34 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I like the ladder bar approach myself , but contact this guy
https://board.moparts.org/ubbthreads/show...rue#Post7323481
Re: leaf elimination on d100 truck [Re: tubtar] #1430923
05/06/13 06:31 AM
05/06/13 06:31 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
4-links are a real pain, my truck has Ladder bars on it...Hooks every time.
http://s427.photobucket.com/user/cudahal...457684573122584
Re: leaf elimination on d100 truck [Re: tubtar] #1430924
05/06/13 07:03 AM
05/06/13 07:03 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I don't know if you're refering to me, I live about 100 miles south of the northern border with Canada. I built a 4-link for my D-100 and like it, much nicer ride on the street. I'm still sorting a few things out but I think it's getting close. My main problem has been dealing with weak links, I first built it when I was making 650hp. I'm now at 850+, trying to build everything strong enough but at the same time keep the weight down to a minumum has been a challenge. Dave
Re: leaf elimination on d100 truck [Re: quickd100] #1430925
05/06/13 09:00 AM
05/06/13 09:00 AM
Dragula Offline
Dragula  Offline
You built a TRUCK into a drag car! I think your out in left field on the weight thing.....
Have you weighed the hood on yours yet? I think mine is heavier than the rest of my cab and I know it weighs more than the bed on mine.
Either way, back on topic, ladder bars are much easier to install and setup, and they hook, and drive very well on the street...And you should need a lot of mods to the chassis if you can find short enough coil overs.
Re: leaf elimination on d100 truck [Re: quickd100] #1430926
05/06/13 10:41 AM
05/06/13 10:41 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Yeah I was........sorry. I could have sworn Nielsville was down Winona / Caledonia way.
I seem to remember a thread where you were twisting the frame rails and how you addressed it.
Re: leaf elimination on d100 truck [Re: BBD150] #1430927
05/06/13 11:17 AM
05/06/13 11:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would want to see what the distance is from the back
of the cab to the center line of the axle... that would
tell me alot and what I would use and do... also what
the balance point is on the truck... if you knew a
couple of these numbers its easier to figure out...
I buy the S&W brackets and make my own bars for almost
every 4-link I install
Re: leaf elimination on d100 truck [Re: MR_P_BODY] #1430928
05/06/13 01:44 PM
05/06/13 01:44 PM
Dragula Offline
Dragula  Offline
They are very front heavy, and also, I believe he would need to put the frame up thru the bed. That is somthing I was able to avoid on mine....
Re: leaf elimination on d100 truck [Re: Dragula] #1430929
05/06/13 02:50 PM
05/06/13 02:50 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I am building a Ramcharger for bracket racing and am keeping it simple. I am using the original leafs with clamps on the front segment, spooled Dana 60 mounted above the springs. At the moment I have front mounts at the rear with longer shackles, but I am going to use rollers mounted to a square tube crossmember that will also serve as the anchor point for the rear tubes of the roll cage. Finally, I will be using a homemade copy of the "CalTrac" system.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: leaf elimination on d100 truck [Re: Polarapete] #1430930
05/06/13 03:44 PM
05/06/13 03:44 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Good luck with the build i been wanting to do this myself
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: leaf elimination on d100 truck [Re: Polarapete] #1430931
05/06/13 08:02 PM
05/06/13 08:02 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Finally....I found a man crazier than me. My factory leaf springs worked wonderful until I went to a 528 Hemi. I tryed the caltracks and shocks and just couldn't get them to work. I called Calvert racing hoping they could make up a set of leaf springs for me. They said they couldn't help me so I fabbed up a 4-link. I bought a copy of Billy Shoppes, 'Just Suspensions' it was a tremendous help. Dave
Re: leaf elimination on d100 truck [Re: quickd100] #1430932
05/06/13 08:37 PM
05/06/13 08:37 PM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
Mine has a 4 bar
Its called the "fatbar" system
from
www.nolimit.net
They ( don't ) make them for Dodge
http://www.nolimitparts.com/prodinfo.asp?number=FTBR-BC
It worked perfect, it was quite the discussion with the tech guys there
I love it
Re: leaf elimination on d100 truck [Re: quickd100] #1430933
05/06/13 09:19 PM
05/06/13 09:19 PM
New Brunswick, Canada
TrxR Offline
TrxR  Offline
quickd100: do you have any pics of the 4 link under your truck?
Re: leaf elimination on d100 truck [Re: TrxR] #1430934
05/07/13 07:06 AM
05/07/13 07:06 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Sorry, I don't have anything current and the shop is plugged with equipment right now and I can't get remotely close to the hoist to get any pics. Dave
