Re: Best place to buy BB steel shim head gaskets?
[Re: Dunnuck Racing]
#1430728
05/05/13 09:26 PM
05/05/13 09:26 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
JOHNRR , thats not bad at all,last time I looked at them they were over twice that much,EACH.. Guess the price was adjusted? Keith
No , they still have that ridiculous priced set also , it's $160 for a pr.
[Re: mosweethemi]
#1430738
05/06/13 11:38 AM
05/06/13 11:38 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Mancini Racing part number SFP-5963 .022 $32.95 Pair plus shipping call and ask for Wess he will help you! from a true Mopar Man Mosweethemi!!!!!!!!!!!!!!!!!!!!
I know guys who have had sealing issues with the Mancini steel shims.
For $10 dollars less it seems like a no brainer to stick with the genuine Mopar gaskets from Summit.
[Re: CompSyn]
#1430739
05/06/13 06:36 PM
05/06/13 06:36 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Those are NOT the Mancini gaskets. They are Superformance gaskets. The correct part number is SFP-5983 They seal just fine, I use them myself
[Re: BSB67]
#1430741
05/06/13 07:13 PM
05/06/13 07:13 PM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
The P515 series gaskets are not even steel shim gaskets....they are MLS hence the high price. I have covered that before but will repeat as many times as folks need: If you want the steel shim spec, do not order the P515-series part numbers.
The old P4286754 are much lower priced, they are now made of stainless instead of mild steel which is a nice upgrade, but availability appears to be poor at the moment from everything I can gather. They appear to be on backorder right now with no ETA listed as of yet.
If someone wants the old spec mild steel like what direct connection sold in the '70s, order OEM gasket number 3614824. There are a few dealers that still have it. It will be the silver painted mild steel most of us are accustomed to.
Rich H.
Esse Quam Videri
[Re: BSB67]
#1430742
05/06/13 07:59 PM
05/06/13 07:59 PM
roadhazard
Akron, Ohio U.S.A.
I noticed your gaskets. Says 0.022" thick. Are they coated/plated? Are the "other" shim gaskets actually 0.020", as years ago, they actually measured 0.018".
Just curious.
Very similar to the old DC #3614824 that Zippy was referring to @ .022" thick
