Re: 69 charger or any b- e- body front suspension problem.
[Re: ahy]
#1430491
05/05/13 11:08 AM
05/05/13 11:08 AM
Posts: 677 Southeastern Ohio
1st_charger
Southeastern Ohio
As a diagnostic, suggest you crank it back up to correct height then mark everything relative to a reference. Paint mark on the rear of the TB's with matching mark on the cross member, ect. Also include marks on the control arm and TB socket and adjuster bolt. Jounce it first to see if anything moves then drive it. I bet you'll find what is slipping.
Also it would be worth extra care working around the loaded TB just in case its cracked and yielding. It could let go with a bang. [/quote
I have done this and the place that its slipping is the bushing on the pivot pin.
[Re: 1st_charger]
#1430493
05/05/13 11:34 AM
05/05/13 11:34 AM
Posts: 1,179 Canada
demon
Canada
Sounds to me like you have the front hex 1/6th out of position. With the upper contol arm rebound removed, the car jacked up and suspension hanging down, the front adjuster lever needs to be in the fully down position too before you slide in the bar. If you have that front lever up too high before sliding in the torsion bar, it will not be able to be preloaded.
[Re: NITROUSN]
#1430495
05/05/13 01:58 PM
05/05/13 01:58 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
That bushing can spin to the end of time and it still wont cause the suspension to drop.
That's exactly what crossed my mind also....How many LCA's have been taken off cars with the bushing basically non-existant and the car is still on all 4 wheels.
