Ron's Toilet or Pro Systems SV1? #1430042
05/04/13 12:40 AM
05/04/13 12:40 AM
montana
BANDIT Offline OP
BANDIT  Offline OP
montana
Who out there is using these set-ups? Pros, cons, will be on alcohol, race only, 9.5 second big block car. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Ron's Toilet or Pro Systems SV1? [Re: BANDIT] #1430043
05/04/13 12:44 AM
05/04/13 12:44 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I really like my SV-1, Patrick gives great service. But the toilet is a great piece also. I might have a little less in my SV-1 than what a toilet costs.
Re: Ron's Toilet or Pro Systems SV1? [Re: DavidDean] #1430044
05/04/13 01:05 AM
05/04/13 01:05 AM
PA
moparacer Offline
moparacer  Offline
PA
I'll take a toilet or mechanical injection system over any carb setup.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Ron's Toilet or Pro Systems SV1? [Re: moparacer] #1430045
05/04/13 01:21 AM
05/04/13 01:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Same here.... the toilets works very well... alot of
really good racers use the toilet and it makes for
a very consistent car... I had a toilet and sorry I
ever sold it
Re: Ron's Toilet or Pro Systems SV1? [Re: MR_P_BODY] #1430046
05/04/13 01:41 AM
05/04/13 01:41 AM
oregon
greendart408 Offline
oregon
X3
Re: Ron's Toilet or Pro Systems SV1? [Re: greendart408] #1430047
05/04/13 10:23 AM
05/04/13 10:23 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
X4....I like the Terminators better than the Toilet(both from Ron's) myself,but FI over a carb. any day.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Ron's Toilet or Pro Systems SV1? [Re: MRMOPAR622] #1430048
05/04/13 11:42 AM
05/04/13 11:42 AM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
I am using a Ron's Terminator from James Monroe (Great Service)
Steep initial learning curve, but very consistent and easy to tune once you catch on...
Incredible throttle response and TQ
Good luck,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Ron's Toilet or Pro Systems SV1? [Re: cudabin] #1430049
05/04/13 04:35 PM
05/04/13 04:35 PM
NC
440Jim Offline
440Jim  Offline
NC
I run the Ron's Flying Toilet, and love it.
A good alcohol carb/regulator/pump system can work great, but if making the switch to alcohol, I vote for injection.
The initial price might look a little higher than a carb setup. But once you include the cost of everything they get closer.
Fuel pump is included with the Ron's kits.
Fuel filter (for alcohol) is included with the Ron's kits.
Fuel regulation is part of the system (no separate regulator).
You need a fuel cell either way, but the injection likes the cell in the front of the car (not the trunk area).
My first few years I just used the basic system.
But then I bought the primer plus system (with spray bar) that allows both starting on gasoline, warm-up and idle driving in the pits all on gasoline. The gasoline primer makes it easier to start, especially in cool weather the first start of the day (50-60 degrees F). So I highly recommend it. Also, I use a 2 qt gasoline tank rather then the standard 1 qt that needs to be refilled often if you drive in the pits with it to keep heat in the motor.
